1995 base 240sx s14: removing driver side exterior door handle
TerminalVelocity
Car: 1996 240sx
Alright guys, I'm having some problems here.
I need to replace the driver's side door lock in my 1995 240, so I'm trying to remove the door handle since I figure this is the easiest way to get the lock out. I've removed the door panel. I've also removed the 2 nuts, on each side of the handle, that keep the handle bolted to the door as well as the linkages connecting to the lock and handle.
The problem is I still can't get the handle out. It looks like the lever that connects to the linkage that opens the door is hitting on the door panel. Also, there's no room to just flip the handle back towards the interior of the car and then pull it out that way.
Does anyone know how to get the handle out?
Edit: Pictures ftmfwTop viewLeft viewRight View
Modified by TerminalVelocity at 1:40 PM 5/9/2008
assassin7420
Car: 1996 Nissan Silvia
1995 Nissan 240sx (daily)
Bad pictures are bad.
TerminalVelocity
Car: 1996 240sx
I've seen that diagram in the fsm already... I don't see how it helps.
I was thinking though. Can the handle even be removed with the inner door skin( the thing the window motor mounts to) still on?
The thing my finger is touching is what I'm talking about.
TerminalVelocity
Car: 1996 240sx
Nevermind. There's a spring loaded clip that goes around the lock cylinder. When you undo this, the lock slides out then you just put the new one in. The handle does not have to be removed.
