Video: Nasty head noise
andromeda
Well some of you may know i just rebuilt the bottom of the motor. Had to put new cams in as well. Now there is a tapping noise. I know its not the timing chain tensioner because its already off. It gets quieter as the car sits and idles as well. And it doesnt really seem to affect the way the motor runs( other than the nasty noise). My buddy who put the car together thinks its the lifters. But i just figured id get some suggestions from you guys. Thanks for the help.
(the noise is actually a lot quieter than the video would suggest. i guess the mic on my phone is pretty sensitive)
Also i found this video. from IDAHOTUNER (i know hes on this forum) It sounds pretty similar to mine. Only his seems a little louder. He mentioned something about the shims. Is it possible that is my problem? Would that be the shims on the rockers? Thanks thanks thanks thanks!
http://youtube.com/watch?v=BC3iFEjPu_E
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
kinda has that sound like it needs oil.
andromeda
that could be possible. I think it may have leaked a little. I havent been driving it really except around the block maybe a few times. But one of the turbo oil lines leaks a little. so that could be the problem. Im gonna change the oil before i drive it again and see if that helps. i gotta get some new oil lines as well!
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
andromeda wrote:that could be possible. I think it may have leaked a little. I havent been driving it really except around the block maybe a few times. But one of the turbo oil lines leaks a little. so that could be the problem. Im gonna change the oil before i drive it again and see if that helps. i gotta get some new oil lines as well!
2lua
Did you bleeded the Hydraulic lash adjuster????
andromeda
when i say leak i mean like maybe 1/5 of a quart haha. TOPS. Dont worry ive maybe driven it a mile. and the dipstick still reads in the normal range. I just know it leaks a little.
andromeda
i didnt put the motor together myself. but i bet the guy who did, did not do that
2lua
If he did not bleeded all the air out of the Hydraulic lash adjusters, then it will make noises like that. you might have to get back in there and rebleed them adjuster... GL
urcaptnspeaking
Car: 2007 Ford Fusion
2001 Honda Accord
1978 Pontiac Trans Am
yeah i second what was said above. Whats you oil pressure on start up and after 15 mins of running. A lot of motors in time... "knock" on start up and for a minute then its settles.....its moe than likely something with it not getting oil. Check the whole "oil flow related" systems
andromeda
ok thanks guys ill bleed them and fix the oil lines and go from there, also been emailing idahotuner, hes a really nice dude and said to double check the position of the cams. I think his were a couple teeth off and it made a huge difference. So ive got my checklist of things to do.
HurryupandrunS13
Car: 1992 240 fastback
Sit em in a jar of oil for a day or two, they'll bleed themselves. That also sounds like it could be a bad timing chain tensioner. Can't tell from the vid, it seems valvetrain related and those lifters will be loud if they aren't bled.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Yeah shes sounds low on the lubrication. But from experience I had a motor rebuild and the crank was out of round by a few thousandths and it did the same thing. I ended up needing to rebuild the bottom again, with a new crank.
At first it almost sounds like a wrist pin.
But check the oiling first before you get worried. New oil pump?
The most important thing is not to run it until its better,
andromeda
ya ive been so busy lately i havent had time to work on it. but it does have a new bottom end including crank so hopefully thats not the case. i should have some time to work on it shortly so i will post back if the lifters were the problem. thanks for the suggestions though guys
i4jdm
Car: 1995 240sx (s14) kouki conversion
hey my ka is making the same noise i think yours is making. it sounds like a ticking sound or something along those lines right? anyways if i is the lifters it would be a minor problem right?
