280z transmission
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
bigred240sx
Car: 91 240sx fb w/ super hicas(wrecked)
1976 280z
2009 frontier
well i recently got my 280 as some of you may know. i heard somewhere that a 240sx transmission will work on the l28 in the 280. im just trying to figure out if its true and if it is what year transmission.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
yup, all 240sx trannies can be used, you gotta modify and reuse the front case and countershaft bearing from the L trans, you might want to search I've done it and it's been discussed, if you can't find it I'll dig around
bigred240sx
1976 280z
2009 frontier
i looked but couldnt seem to find itand one guy who talked about doing it posted it up on another website, but i cant veiw it because im not a member
evildky
06 Nissan 350Z GT
I did the writeup, and poste din on Hybridz.org years ago, not a sticky just in a regualr post as I had a hard time finding the info back when I did it, so here si the rundown:
you need, a 5 speed trans from any 240sx, any year, even the 84-86 300ZX N/a trans as well as I believe several other less popular applications fo the same transmission, you'll also need a datsun, L series transmission, any 71.5-83 is find with the exception of the 82-83 280ZX Turbo T5, anyhow...
you take the front case off both transmissions, it's pretty simple, you'll see the bolts holding the 2 halves together in the middle of the transmission, there are also some bolts in the bellhousing area that hold the cover over the mainshaft bearing and selector shafts, there si also a large snap ring here you'll have to pull, you'll need to take the front case, and countershaft bearing from each trans and swap them.......to put the front case from the L series trans on you'll have to overbore the 5th/reverse selector shaft hole, you'll know which one as it's smaller and won't allow the selector shaft of the new trans to go in, some peoplehave had to do some clearancing on the inside of the case, mine fit without issue but if you do a dry fit and try rotating it if you feel drag pull it apart and grind that area......seal up the 2 halves with RTV, as well as the endcap in the bellhousing area, your exhisting clutch and flywheel To bearing etc all remain unchanged but any 70-83 flywheel and clutch combo will work........bolt the transmission back in, the trans wil lean to the passanger side a few degrees nto a big deal, you'll need to cut your trans crossmsmber into sections, reposition the sections weld them back together and brace up the seams, you'll need to have a new driveshft made using the slip yoke form the 240sx and the rest fo your old driveshaft to the length needed depending on your diff setup
it's not a bad as it sounds if you have some basic fab skills, if you can find an 82-83 280ZX Turbo 5 sped it's easier and a stronger trans, the Z31 guys are wrong about which trans is stronger
bigred240sx
1976 280z
2009 frontier
thanks a million i have all things needed for it even the 240sx transmission just gotta build it or at least change the synchros
redhat-z
Dave, you should sticky this thread. Yea, I know.
Pharaohabq
Car: 92' Nissan 300ZX NA
So Why would you want to Swap out the transmission? Is the original 280Z transmission very weak when it comes to increasing engine power (adding a turbo et al)????
Phar
evildky
06 Nissan 350Z GT
nice avitar steve
the vast majority of S30's came with 4 speeds, so a 5 speed makes the car a lot less annoying at interstate speeds as it adds overdrive, the 77-78 had the option of a 5 speed but they are rare and if you put the power to them they break, they just kinda added an overdrive to the stock trans and they did a poor job of it
Pharaohabq
Ahh, okay, That explains it, Both the S30's I've had had the 5speed transmission already. I'd kinda assumed it was standard equip. My old one was a 2+2 n my "new" project has one and it feels pretty good, though I haven't actually driven it yet. Probably I'll keep it tille I experience an "Upgrade Opportunity." Phar
sdzxdriver
Car: 1982 280zx
It's also nice that in case something with the transmission goes south, you won't have to worry about there not being a parts car at the junkyard. It's getting hard to find Zs in the yard now.
reggiegsd
Car: '94 Q, '73 240Z
sdzxdriver wrote:It's also nice that in case something with the transmission goes south, you won't have to worry about there not being a parts car at the junkyard. It's getting hard to find Zs in the yard now.
Look for a rusted '82 or '83 ZX with a good drive train. The entire drive train and a few other bits will swap into a your 280Z. Unless you are building a turbo motor or an outrageous NA motor the Z transmission will hold up. This is the best L-series motor and transmission and they will directly swap into you 280 with virtually no modification. A nice "Bull Frog" cam (Do they still exist?) and a clean 2.5 inch exhaust and you will have an honest 210 HP.
Reggiegsd
Return to “Datsun Z Forum”
