It seems that someone with a SRT4 neon also did a very lengthly test with many plugs on a dyno. So it is not comparing to an old fouled up plug. I would love to see this test done on the VQ.auditech10 wrote:And how have they compared these plugs to??? Old foulded plugs vs new plugs(any kind of brand) will net performance and mpg gains. For me, unless I go forced induction, I will stick with the OEM plugs as this motor was designed with.Cheers
I am very suspicious of any test that says a particular plug produced the most torque but not the most horsepower as HP is just a number calculated from the torque data for any engine.auditech10 wrote:And how have they compared these plugs to??? Old foulded plugs vs new plugs(any kind of brand) will net performance and mpg gains. For me, unless I go forced induction, I will stick with the OEM plugs as this motor was designed with.
Ryan, I would strongly suggest sticking with the OEM plugs - with the two available "hotter" and "colder" options! The Nissan and Infiniti engines are notorious for eating other brands - no matter how good they are touted to be, and no matter how "reliable" the brand/source.Boon wrote:So I am thinking about dropping $200 on spark plugs. According to them they're suppose to be the cats balls.
Using there 6% better fuel milage estimate they would net me $210 (70 gallons if i only drive 24,000 a yr) in gas savings in 12 months, and that is at $3 a gallon which lord knows we are probably never going to see that again for premium.
Here is some info on the plugs. http://www.pulstarplug.com/index.html
Any ones input on them would be appreciated. I am pretty knowledgable about the ignition system and how it works, so it all seems to make sense, but I also worked in marketing and know how that side of things goes also. I could probably pay 1/3 the price and save 3% with some iridium NGK's.
Let the discussion begin........... please
Our collective experience, over many years of Infiniti ownership (I bought my first one in 1991 for example) and watching what has happened to people (e.g., who tried Bosch spark plugs and had pieces break off and score cylinder walls, etc.), leads folks like maxnix and myself to warn you strenously.
Finally, no spark plug change (away from OEM in this case) is going to give you any significant or perceptible increases in horsepower or reliable improvements in gas mileage, etc. Anybody who says otherwise is fooling themselves.
Z
What makes you think the iridium is an "upgrade?" Spend some time reading at the NGK website as it is very informative.Boon wrote:Would you say don't even upgrade to the NGK Iridium's? Is even that pushing it? Let me know as I value you long time owners
Honestly cost is always part of the equation, and new technology is always changing. My engine was made 6 years ago, I'm sure there have been many advancements within that time. I know these engines were not made to be supped up so I realize your guys concerns, just saying there are always two sides to a coin.maxnix wrote:
Let me ask you this, if Nissan thought an iridium plug would work better, wouldn't the engine be designend with that plug?
Again depending on what A/F mix at the computer, a so called up grade can rob performance. Many engines designed for copper top plugs will BURN lean with platinum plugs and drop performance and INCREASE TOP END WEAR.Boon wrote:
I searched for a bit more information on the other NGK brands recently. According to some info (admittedly a bit dated now) that our CEO got from an NGK person, the Iridium was designed for four-cylinder cars and not intended for high-end V-8 applications like our M's and Q's.akliquid wrote:Wondering if you changed out your spark plugs to something different than OEM. Was thinking of putting the NGK IX Iridiums. Wanted to know what you eventually went with. Thanks
zerothread?id=220akliquid wrote:Wondering if you changed out your spark plugs to something different than OEM. Was thinking of putting the NGK IX Iridiums. Also because on SPARKPLUGS.COM, the Iridiums are $8.00 compared to $11.71 for the double platinums. Wanted to know what you eventually went with. Thanks
Old yes, but each plug and each particular combustion chamber for which it was designed has not changed!Azhitman wrote:I spoke at length with an engineer from NGK here in the Valley, back when I was considering the NGK iridiums vs the platinums. He explained to me that the iridiums are NOT designed for an environment such as the Q's combustion chamnber and unequivocally cautioned against using the iridium plugs in anything but the low compression 4-cyl for which they were degned.
I don't really think an American turbocharged 4 cylinder is a good basis for test data regarding a Japanese V8.jadeM45 wrote:
It seems that someone with a SRT4 neon also did a very lengthly test with many plugs on a dyno. So it is not comparing to an old fouled up plug. I would love to see this test done on the VQ. ...The test vehicle was a stock 2005 Dodge Neon SRT-4....
