97 maxima egr solenoid location
onefast
Car: maxima
I have code 1005 pop up can someone please give me some info. i have searched for hours and can't find much... i have a chilton manual but did't help much. The only quess I have is by the transmition dipstick. manual shows 1 I have 2. One sensor has a green colored electrical connection other is black. Any suggestions on replacing the part or looking for other problems first. thank you
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I'm not familiar with a 1005 code. Are you sure it isn't 0105 or 1105?
onefast
Car: maxima
1005: EGR solenoid valve circuit. I also seen it as an egrc selenoid. I think under obd it is p1400. dealer was no help for parts all they said is they have a listing for 3 selenoids and need the part number because their database lists them as selenoids and doesn't state any additional info.
maxhopper
Car: 02 Maxima SE 6spd
onefast wrote:The only quess I have is by the transmition dipstick. manual shows 1 I have 2. One sensor has a green colored electrical connection other is black. Any suggestions on replacing the part or looking for other problems first. thank you
It is one of those two solenoids, but I can't remember which off the top of my head. Follow the rubber hose coming off the bottom of the solenoids, and see which one leads back to the EGR (below the throttle body).
onefast
Car: maxima
still having trouble figuring out which one it is. One is black and the other is actually brown not green. off the top of your head is the one connected to the boost sensor the egrc?
onefast
Car: maxima
found it....was the green end capped solenoid...totally dead i get no ohm reading at the terminal. I also found out what the other 2 selenoids are if anyone needs to know.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Glad to hear you got it sorted out!
david37072
Car: 1998 nissan maxima
i have the same code is the map solenoid the green one? more help would be appreciated
david
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
http://www.nicoclub.com/FSM/maxima/1995/st.pdf
Work back on this url to your car. This is the floorshop manual
david37072
thank you
david
david37072
code 1400 is the map control solenoid. don't ask me why it comes up egr solenoid in the codes. for anybody that can use this information. it is located on top of the engine and has a green connector
mrubio4602
Car: 95 maxima
Hello I have a 95 maxima that is giving me an egr solenoid error, Do any one knows which of the two solenoids is the one for the egr, there is one mounted on the motor in the bay where the knock sensor is located the solenoid is green; the other solenoid is by the battery in the front of the motor and it is all black in a metal bracket.
DebL
Car: 1997 Nissan Maxima
Just wanted to say 'thanks', need to have this replaced in our car - helps to know what the codes mean.
