skycat »
https://forums.nicoclub.com/skycat-u44583.html
Wed Feb 20, 2008 11:42 am
VH41DE to RB gearbox.
This price has been worked out based on a run of 10 units. You are looking at $2300 (incl. GST). This is a preliminary price as I am still waiting on a confirmed quote to machine these up.
The kit will include--Full Carbon Fibre moulded adaptor.-Machined, drilled, tapped, doweled, all clearances checked e.g. fly wheel, starter motor, front prop shaft etc. (The adaptor plate is 1.9 times lighter than an equivalent sized billet aluminium unit and 1.3 times stronger than aircraft grade alloy.)-12.9 grade Cap screws, for both the VH side and the RB side (i.e. No extra bolts needed) -Metric Washers, grade 10.-Flywheel spacer made from Chrome moly and supply of all relevant fasteners (This unit will be balanced.)
AWD or RWD (In regards to the adaptor itself, our mould can do both as it has a removable piece for this application). This needs to be specified when being ordering.
This kit will allow a successful mating of a VH41 (RWD or AWD) to a RB box (GTR or other). No extra bits needed. Ready for a clutch to be put behind it.
It is being built as a top level motorsport item and will stand the test of time. There wil be no issues with this adaptor, even on the big hp cars ie 1500+
pics of the adaptor plate
