rb26dett with t88-34d
njc.corp
Car: vl calais rb26det
am i in the right section if i want to ask for a estimated power output if i list my combo
if i have listed in the wrong section -i am sorry-
ArmadaJspec
Car: ECR33 Skyline Type-M
Really depends on what your doing to support the T88 on your RB26.
Mine was engine dyno by T.M. WORKS @ 785whp. using Power FC, T88H-34D on N1 R34 RB26 bored to 27mm. HKS Internals/ Sard 950cc injectors/ Twin Bosh F.P/ etc.
hope this helps man.
ravera
Car: 1971 Datsun 240Z
You could easily be in the 800+ range on a fully built motor. Then again you could be at 0whp as that turbo is big enough to eject every part of the bottom end out of it. With only 2.6L of displacement moving that big ol' snail, the graph is probably going to look something like ___/ unless you get alot of NOx to spool it. That said, with a fully ported head, big cams, and a fully forged bottom end, 700+ wouldn't be out of the question.
What setup are you running? Cams? Porting? bottom end? intake? fuel? Engine management?
brokendreams
Car: 1991 240sx
I am in the process of building my engine for my awd 240sx. what do you think of my setuo and if you have any recommendation tell me....
r33 rb36dett
BlueprintForged pistonsForged rodsarp rod boltsarp head studstomei thick head gasketHKS valve springs and retainers tyoe Btomei ValvesHKS 272 camsBIG Black HKS intercooler w/ cry02T70 turbo( but im thinking about going bigger)custom downpipe to 3 inch hks hi power exhaust
hks fuel rail1000cc injectorsgreddy intake manifold 90mm throttle body2 255 walbro fuel pumps
aem stand alone
