blazncypher wrote:ebay has them. if you cant find them for the i35 try searching for the i30 ones. i ordered some for a total of 150.00 w/shipping and handling. the only problem is the angel eyes are a little dim (cant really see in the day) and the projector beam needs to be adjusted after you install them. it is easier then having to buy projectors, retrofit them and create angel eyes.
The problem with those is that the projectors inside them aren't very good at all. They're definitely not designed for HID either.
If he's got an I35, then he already has OEM HID. He'd either have to convert to halogen (bad), put in an aftermarket HID kit (bad), or retrofit some proper HID projectors in there.
The last option is what I did, actually. I bought the eBay lights and then modified the brackets inside them to accept the TSX projectors. I then mounted the OEM ballasts in the factory location under the headlights and then used OEM wiring harnesses to connect it to the car.
