elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun Mar 04, 2007 1:31 pm
Some of you know a few weeks ago, I went and got a bunch of free Q parts.. Most of the stuff was useless, except the brakes, but I took it anyway.. I figure my attic has almost enough to put together half a Q, why not make it 55%..
So while I was there, I took some of the intake parts. The abstract of what I did was take the "air horn" off of a 90-93 and dropped it right onto the stock intake tract on my 94. NO modification required, just take the other one off and put the new one on! thank you nissan for not changing it...
on the 94, you can see where the intake comes out at. This is on my old 94, its the only picture I have of a stock 94 intake, except on most Qs theres a trim piece there, however it is missing on this picture, but its almost better for the sake of illustration
Thumbnails are clickable to enlarge.
Look just inboard of the drivers side headlight, you can see where the airhorn is on a 94. normally there is a trim piece in front of it.
Here is a picture of the entire intake before the airbox removed from the car. the piece on the far left is the only part from the 90-93, the rest is as it is on the stock 94.
Intake assembled.
For some reason the previous owner thought it would be good to strip down the intake and leave a bunch of holes, so I sealed the holes up with tape so that it can maintain pressure.
Here is a couple shots of the final product installed.
Driving impressions...
Well, you cant expect a whole lot from something like this, however I definitely do think that it pulls a little bit harder, and it seems a lot more jumpy then it was before. When you put your hand in from of the air horn and rev the motor you can feel the air being sucked in, so it must be fairly leak free... Overall, this cost me about an hour (not all a loss because I had to attend to something else while I was in there) and parts cost me nothing, so im a happy guy... Plus, I used all OEM Q45 stuff!
