I started this project yesterday after driving on the highway for six hours and finished it today. I converted my convertible to 5 speed a while back and just made it where my top worked. Also, make sure that when you swapped the 5 speed, you connected the brake kill switch (for lack of a proper name), that turns off cruise control when you press on the brake pedal. After I swapped my SR in I decided it would be nice to have. First I swapped the SR throttle body with the KA throttle body. The SR's never came with cruise control and thus they do not have another throttle pulley for the cruise control. It is necessary to do this. When you change the throttle body use the KA TPS and just change the connector or just directly connect the wires. They should be the same color and it should work. For the coolant line on the throttle body, I just connected the two hoses with a piece of pipe and did not run it through the KA throttle body.
I connected the speed signal wire from the cruise control module to the ECU. If you do not know how to do this, here is a link with pictures.
zerothread?id=182123
Now for the inhibitor switch wiring. In the wiring there is a wire that completes the circuit. This is the black wire. Depending on which wire it is connected with, that tells you car "what gear it is in." On the connector, the green wire is used for reverse lights. I just wired that to the reverse switch in the transmission so that it worked how it was supposed to. The blue wire is to tell the car that it is in park or neutral, which for convertible owners, allows the top to work. The yellow wire tells the car that it is in drive and this is what allows the cruise to work. None of these can be connected at the same time or the cruise will not work. The reverse is fine as long as it is wired into the switch for the transmission. In order to get the top to work and get the cruise to work you need to make a switch. Only one will be able to work at a time. I am cheap and just cut out the overdrive switch in the stock auto shifter and used this.
That is what I did and everything worked fine for me...I hope it works for you too. As of now my clutch pedal kill switch does not work but it'll work for now.
