Search! Don't forget year and model of your car either
180fan
Car: 89 fastback
When you're making a post
don't assume that the members here know what car/engine you're driving. Just because this is a 240sx tech section, doesn't mean I know what type of engine you've got in there. There are too many different engines that I have seen crammed into the engine bay of the 240sx. This becomes an issue for members later on that encounter the same problem and actually use the SEARCH function and need to pull up relevant threads without alot of bs.
Don't put "help pls!" or some other lame title as the topic title. Don't waste the time of the other members on this site if you're in need of help. Make the topic title detailed and relevant to your issue, not some weak plea for help.
electricman
Car: 98 240sx
great post
95blackzenki
Car: 95 black s14
Got it.
doctortomek1
Car: S14
True. I too, once found myself to be a victim of such ignorance.
kdub41
Car: 1993 nissan 240sx se hatchback
will just wondering but does a 2 way lsd make a lot of noise when turning slow??? and where can you buy those sleepy eye conversions??? if you know please get back to me asap thanks man
lilbill0
Car: 1990 240sx se
well kdub41 for your questions as far as i know lsd's do make a small sound when you are making a tight turn, this is based off what i've read about lsd's and for sleepy eye conversion its like $5 bucks there are plenty of write ups about it all over the web, you'll find'em if you look
boett39
Car: 1995 240sx
got a 95 240sx red top sr20det with 740 injectors and my car floods and dies and idles really rough usually you have to hold it down at WOT to keep the car running at that time it does drive fine when you are driving it but you can tell there is to much gas i have a apexi neo and everything anything you can do to help me with this problem
BrianV8
Car: 89 Skyline GTS
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
boett39 wrote:got a 95 240sx red top sr20det with 740 injectors and my car floods and dies and idles really rough usually you have to hold it down at WOT to keep the car running at that time it does drive fine when you are driving it but you can tell there is to much gas i have a apexi neo and everything anything you can do to help me with this problem
wow not one period in that whole thing! Maybe you guys would get help if you started a new thread!
rbs1326dett
Car: 1990 nissan 240 sx s13
hey i got a s13 ka24e........... it wont idle unless i give it gas and hold it down but if i take off a hose off of the inatake manifold and spary carb cleaner and keep sparaying while staritng it idles perfect.... but when i stop 5 sec later it stops and wont wanna run....a nd ideas????
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
it is not getting enough gas. (Your using carb cleaner on an injector?? wtf??) anyways check your fuel pump, lines, ect. Also check to make sure there is gas in the tank. lol. jk
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
oh and something I forgot there is a vacuum line on the left hand side of where the intake hose goes on. with out the line connected it will not idle unless your foot is on the gas.
sleeper180
Car: 92 240sx hatchback SE & 95 240sx s14 zenki
doctortomek1 wrote:True. I too, once found myself to be a victim of such ignorance. <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... con_bs.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... s/bash.gif" BORDER="0">
hahahahaa i also have once followed that path of ignorance but it was a mistake i swear lol
