how to remove oil filter and spark plugs
miata007
Car: 2009 Cube 6sp, 2005 G35 sedan
I did a search on "oil change" and found none that shows me how to remove an oil filter. I recently purchased a 97 Q45t (2 mo) again and want to change the oil this weekend. I remove the air assembly and saw a small oil filter next to the fan blade. The room is tight to reach in from top. From the bottom, I don't see much space as well even if I remove the bottom covers. I don't have FSM so can somebody help with this simple routine.
Also, how can I replaced the spark plugs. Sorry I haven't done a search on this one. I once removed the engine cover. Is this a tough job that requires the removal of the plenum before I can get to the ignition coils?
Thank you for your help!
007
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
All oil changes are done properly from underneath.
There are several posts in Infiniti Mechanic forum, including mine with coilpacks in the title. Only the intake between the Air Filter and the TB needs to be removed.
Best to have high temperature lubrication and a torque wrench, lots of clean rags and some carburetor cleaner on hand.
Modified by maxnix at 6:30 PM 10/12/2005
redmanfx
Car: 92 Q45a
Remove the oil filter from the botton and you're right, theres not alot of room.
The spark plugs take a while and will test your patients. 3 - 4 hrs of cursing and making a mess should be expected! Remember to stay away from the Bosch platnum plugs. IMHO they suck! NGK platnum are the best.
red
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
just remember that fy33 oil filter is waaaay easier than the filter on the G50. HG50 even worse with the extra active plumbing. FY33 also has a catch cup which helps keep things cleaner. if you must use a filter wrench, the kind that are a band, but tighten when you use a 3/8 ratchet [with 3 inch extension in the case of the Q seems to work well].
<<hijack>> anyone know if that catchcup acan be refitted to the G50 [the threaded holder/adapter/bracket is a bit different i believe--at least i put an m1-110 on the fy33, vs. m1-208 for the G50.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Honestly I think an oil filter relocation thing would be a good move... Make it so you can easily access it from under... once for the 300ZX will work as they use the same filter.
miata007
Again, mine is a FY33. Do I remove the covers from the bottom? Thanks for all the replies.
007
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
miata007 wrote:Again, mine is a FY33. Do I remove the covers from the bottom? Thanks for all the replies.
007
That's the first step.
Just one large under engine tray, or drop the left side if you are lazy. Best to drop and inspect everything.
miata007
Brain,Can you give me a little bit more help regarding the search. I try looking up "coilpacks" in Infiniti Online Mechanic section and have no luck. I am still trying to find out how to replaced the sparkplugs, coils, and fuel injectors (if needed), and even the knock sensors.
Thanks!
007
Chansen
Car: Q45
I just did my oil this weekend and it was easier than it looks.just becareful screwing that plastic cover back on cause its easy to over thread or reverse thread or what ever you call it1st oil change on my car that i did myself yay,she was spoiled and always went to the dealer.I put mobil1 extended performance and sofar everything is AOK
PoorManQ45
The oil filter removal on the G50 is fairly straight forward. I have found that going at it from the top provides more room. Remove the top of the air box and the filter, then unbolt th ebottom and remove it. This gives you plenty of room to remove the filter.
elwesso
2007 BMW M Coupe
I found its pretty easy from the bottom if you use a cap filter wrench.....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
miata007 wrote:Brain,Can you give me a little bit more help regarding the search. I try looking up "coilpacks" in Infiniti Online Mechanic section and have no luck.
Sorry, I should have cited "coil pack."
zerothread?id=117157
miata007
Thanks for the link. I find it very helpful.
007
q45rida
i also have a 97 q45 infiniti. and i cant fit the wrench over the oil filter with the limited space. do i have to remove anything else to remove the oil filter
please respond asap
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
I'm assuming that you are working under the engine to remove the filter. It's really a tight area. I have a Vise Grip 12LC Large Jaw Locking Pliers that I bought from HomeDepot @ 10 years ago. It always work, regardless of the oil filter size and location. You can also use a Channellock or equivalent Oil Fillter Pliers, for $20 or less (it's a pliers, not a swivel handle or band type oil filter removal tool). It should would in your Q. Just a reminder, always hand-tight the oil filter during installation.
