Movingviolation240
Supporting Member
Big boost and flying are 2 of the 3 things I can't turn down
200 ft above your house inverted
4-25-2002
I got this off my old standby website Nissansilvia.com out of australia, might be of some use to you guys since Nissan seems to use a lot of the same part numbers internationally. Part type Nissan Australia part number Other source or comments Oil filter 15208-H8911 Ryco Z145A (CA18 all?) Door bump rubbers 01658-J7000 (Skyline R31) Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner Intake manifold gasket 14035-53J10 (SR20 all) Turbo inlet flange gasket 14415-75F10 (200SX) or 14415-17M00 (S13 all) The Aust 200SX one fits. Turbo outlet flange gasket 14445-26E00 (S13 all) Engine front oil seal 13042-42L00 (CA18 all) Engine rear oil seal 12279-18V00 (CA18 all) Oil pan seal front 11121-01F10 (CA18 all) Oil pan seal rear 11121-01F15 (CA18 all) Head gasket 11044-51E00 (CA18 all) Head gasket 11044-50F00 (SR20) until 9/92 Head gasket 11044-50F01 (SR20) from 9/92 till 7/93 Head gasket 11044-50F10 (SR20) from7/93 onwards Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits Engine gasket kit 10101-56E25 (CA18DET) Engine gasket kit 10101-50E25 (SR20DET) Engine gasket kit 10101-51E26 (SR20D) Valve grind gasket kit 11042-51E25 (CA18 all) Valve grind gasket kit 11042-50F25 (SR20 all) Fan belt 11720-V7301 (CA18 all) L = 855mm Fan belt 11720-52F00 (SR20 all) Compressor belt 11920-V7301 (CA18 all) also suits power steering pump Compressor belt 11920-30R10 (SR20 all) also suits power steering pump Water pump 21010-V5528 (CA18) until 8/90 Water pump 21010-V5529 (CA18) from 8/90 Water pump 21010-52F00 (SR20 all) Thermostat 21200-V0201 (CA18 all) 82.0 C Thermostat 21200-V0206 (CA18 all) 88.0 C Thermostat 21200-53J00 (SR20 all) Radiator cap 21430-01F01 Radiator hose - upper 21501-35F10 (CA18 all) Radiator hose - lower 21503-35F00 (CA18 all) Radiator hose - upper 21501-52F00 (SR20 all) Radiator hose - lower 21503-52F00 (SR20 all) Bonnet bump rubbers (large) 62840-D0100 (Skyline R31) Engine coolant 10120-89904 Castrol Dash switch back lights Nissan Aust, have similar types $11.00 each **** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ). Wheel nut 62840-21001 (R31 Skyline) Brake pads See service info page. Bendix and others. Headlight globe Who cares Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam. Rear Dampers ( shockers ) See Nissan Dealer or Nismo KONI. Part no. 80-401-081 sports kyb. Approx $315 a pair. Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 Air Filter 16546-V0100 (same as R31 Skyline) K&N high flow reusable type P/N 33-2031-1 Spark plugs 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm) Spark plugs 22401-53J16 (PRF6B, SR20DET) Crank angle sensor 23731-85M10 (CA18 all) Crank angle sensor 23731-50F01 (SR20 all) Coolant temp sensor 25080-89903 (S13 all) Oil pressure sender 25240-89920 (S13 all)
hurddawg
anything with 4 wheels.
Yokohama
7-23-2002
sr20de's timing chain will work
<--Uruseiyatsura's Moroboshi, Ataru.1994 Infiniti G20 (QN0)---I/H/E/FW + adv ign. SR20DE [SOLD] 1991 240SX SE Coupe (KH3)---Kouki Blacktop S13 SR...Miss it
hurddawg
Yokohama
7-23-2002
take your gates part number to any parts store they will get you the proper belt.I did this at my local place and they gave me Dayco belts and they worked fine. The guy told me that part numbers for belts are standardized. So they can cross-reference them easily. K050370 Alt K040345 P/S K 05 0370....05 indicates # of ribs, 0370 indicates length of the belt. K signifies its made my Gates.
cnichols
96 Nissan 240SX, 99 Infiniti Q45, 93 Ford Fastiva
Balling Green KY
8-6-2002
Also...for those running standalones that use GM style connectors (Electromotive, etc.), a 1998 Corvette coolant temp sensor threads right into the stock sensor location and of course uses a GM style connector.
11.85 @ 123 mph | 98 LS1 | Cam only (MS3) | LS6 Intake | 6 Speed & N/A
 C6 Corvettes are SLOW. 96 240SX SE...Single Cam Swap
Phax
Control dynamics
Long Beach, CA
11-12-2002
The crankshaft main bearings and thrust washers from a 92 SR20DE will fit a 92 SR20DET.
1992 S13 CoupeS13 SR20DET - K&N intake, HKS RAS, Grex Springs, Grex 1.2mm headgasket, Trust oilpan, ClutchMasters kevlar clutch, Fidanza flywheel, HKS 75mm downpipe, Megan Racing 3inch exhaust Walbro 255lph pump Eibach Pro-Kit, KYB AGX, Cusco front strut bar & rear tie bar, Whiteline swaybars, LCA and TC bushings, Moog TC rods, Brembo discs, Hawk HPS pads, stainless lines
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
Alrighty so I can use the following 91 SE-R parts in my timing chain job? 13028-00008 Timing Chain 13070-00008 Timing Chain Tensioner 13079-00001 Timing Chain Tensioner Gasket 13085-00004 Timing Chain Guide - Tension Side 13075-00004 Timing Chain Guide Tension Side Bolt 13091-00005 Timing Chain Guide - Slack Side 13094-00003 Timing Chain Guide Slack Side Bolt 13510-00002 Front Crankshaft Oil Seal 15066-00003 Front Cover O-Ring and those badboys will work no prob in the DET eh? I got those parts and part #'s off of courtesyparts. thanks
1. Search 2. Lurk moar 3. Don't post till you've searched 4. Don't forget details. We're not mind readers over the internets.
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
The o ring sits behind the front cover bascially under the water pump. The timing chain tension side guide for USDM spec is better than the JDM one since the USDM one is metal while the JDM is all plastic. The intake collector gasket is different from the SR20DE. So is the turbo inlet gasket from that of the VG30DETT. You'll have to take a file to the gasket's bolt holes to make it fit. I'll list more erratta as I encounter them with my build up.
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
The connecting rods from the DE will work in the DET.FYI guys, the DOHC KA and the SE-R spark plugs will work in the SR20DET. checked with NGK australia for the part numbers and got PFR6B-9 for double platinum plugs and got BKR6EIX for the iridium plugs. Checked NGK USA and found the BKR6EIX-11 are DOHC KA and SR20DE plugs. The DET uses a smaller gap, 0.036" unlike the DE that uses a 0.044" gap but according to NGK's website gapping/closing the NGK plugs is not recommended < or > 0.08" so we can tap it closer. Or you can just leave it since I was told by HT that the gaps are the same for the SE-R as the DET.
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
Blacktop O2 sensors are the same as the 95 300zx twin turbo o2 sensors. They're the fat type that phase2 has.
turboimports
saint paul
11-13-2003
question for my redtop s13 sr20det. anyone know about the 5/6 plug on my harness for the tps? i have one like this, some say it only comes with the 50mm throttle body. wich im not sure if mine is or not. it doesnt hook up to my sr20det wiring harness, because my harness is only for 3 plugs or something. some also say that i can replace the tps with one from a 91-94 usdm sentra ser? is this right? bolt up?thanx -Lor
91 NX2000-98 JDM SR20DE, 10.0:1 compression, low-port -Nismo intake -Hotshot header -Borla exhaust -2.5" piping -MSD 6AL -MSD coil -MSD distributor cap
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
the SE-R's is compatable with the turbo SR's. Just make sure you've a 3 wire plug. I've not seen the 5 or 6 wire TPS for the SR's, all of them I've seen are 3.
Hijacker
240SX Moderator
'92 240sx Convertible
Olney IL
8-13-2003
got some new part numbers for everyone. I unfortunately threw out my 5 hole turbo to O2 housing gasket bag before I could copy the part number down.14415-17M00 4 hole gasket Exhaust manifold to turbo 32516-V5002 Shifter retainer plate gasket
-Bart
| Quote » | Originally posted by Movingviolation240 What hammer, all I see is a Poundometer, it's a percision adjustment tool. |
| Quote, originally posted by audtatious » | Hey wait. My balls don't hang too low yet |
S13 Auto -> Manual Swap / My 240SX / Convertible Top Replacement / Silvia Fog Light Wiring / DIY: SR20DET Rebuild Stacey L. Childs, NICO Mom
ca18det_boy
I35 160mph
12-24-2003
MY TURN!!!!! S14 SR
Rear Main Seal Set---------------BS 40628 (felpro) Oil Pump Screen gasket---------15053-1e400 Main Bolts---------------------------12293-53j00 Oil pump screen--------------------15050-53j13 Pilot bearing-------------------------14658 (motormite) clutch fork springs------------------30514-14600 clutch master------------------------cm39754 (tru torque) Injector O-rings (where it meets the mani)-----16636-72p00 Head bolt washers------------------11058-53j00 rod nuts--------------------------------12112-40f00 fuel rail spacers-----------------------17522-10v00 Connecting rod bolts-----------------12109-60j00 Clutch slave----------------------------cs37493 (tru torque)
(\__/) 91 Turbo II - RIP - 90 Hatch - Sold (='.'=) 90 Turbo II - RIP - 91 Hatch - Sr20det 236 whp (for now) (")_(") 89 Hatch - Sold - 92 Coupe - S14 Sr20det 525 whp (clocked 163) 03 GSXR 1000 - New personal land speed record, speedo reported 202 mph
Hijacker
240SX Moderator
Olney IL
8-13-2003
here's another couple22020-50F00 Ignitor Chip 14052-21R00 Exhaust Plug (for AIV inlet) 14064-7B000 Studs for O2 Sensor Housing
s13sr20chris
nissans
newport news virginia
6-10-2003
jwt says that fwd sr20de piston rings will work on rwd sr20det's. i am goint to use them on mine.
http://www.freakedforjesus.com/
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
Front timing chain oil jet can be used from the 91 SR20DE.
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
Rocker arms part number 13257-53J03Rocker arm guides (little grooved shim thing on top of the valve spring retainer) part number 13218-53J00
Hijacker
240SX Moderator
Olney IL
8-13-2003
JDM part number Cam Angle Sensor: 23731 - 50F02Not sure if there's a US equivilant for it. The P/N for the CAS is on the cap, so this is for those of us who never received a CAS cap
cheapspeed
96 se
atlanta
6-15-2004
a 95 and up alternator will bolt to a s13 sr with some slight modification to the tensioner mounts
stiergott
240
6-18-2004
i have a ka starter bolted to my sr. all you need to use is the ka mounting bracket. if you need more info just ask
SoCalS14
My car...duh
So Cal
3-3-2004
S14 SR OIL FILTER = 15208-65F00
Shift_Zenki
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
S13 SR TPS can be sourced from the 97 200sx.
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
Parts numbersFront cover o-ring 15066-4j600 tensioner gasket 13079-2j200 front crank oil seal 13510-53j10 throttle body gasket 16175-53j00 timing chain oil jet 13081-53j00 Intake manifold to head gasket 14035-53j10 Piston ring set (std bore, #1 on block and pistons) 12033-53j20 Connecting rod bearings (blk) 12111-1n501 Connecting rod bearings (brn) 12111-1n500 s13 Oil filter 15208-53j00 Nismo tranny mount 11320-rs541 Crank bearing (blue) 12207-60j04 Crank bearing (yellow) 12207-60j03 Crank bearing (green) 12207-60j02
Modified by 180fan at 3:08 PM 10/19/2004
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
ARP Main Stud kit (arp part #) - 202-5402 ARP Head stud kit (arp part #) - 102-4701 ARP Rod bolt kit (arp part #) - 202-6005
SoCalS14
My car...duh
So Cal
3-3-2004
Quick parts update:Studs for attaching the valve cover: Part # 13508-53J00 Will work on Redtop/Blacktop/Notchtop Broke one of mine, had to find a replacement...totally sucked...
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
Throwout bearing - 30502-21000Nismo clutch fork pivot - 30537-RS540 Intake valve oil seal - 13207-D4201 Exhaust valve oil seal - 13207-2B500 (These two parts are from Chris' detective work, I just found the part numbers for 'em)
s13sr20chris
nissans
6-10-2003
| « Re: (9095240SXDUCK) | 3:43 AM 12/2/2004 |
fwd head gasket does NOT work.
mynameisjonas
Perkasie PA
7-14-2003
i need the throttle cable bracket, the one above the throttle body that holds the end of the cable and that you tighten the nuts down on the cable so it doesn't move. make sense? it's for sr20det redtop. is it the same one off a regular sr20de?
Asia989
93 240sx
Brandon,fl
5-18-2004
will the rocker arms off of a se-r 200sx fit a sr20det,same thing with the timing chain and guides if it has that?
High Curbs and Drifting just dont mix No Front Bumper mafia member
180fan
Supporting Member
89 fastback
San Francisco
12-14-2002
Update: The ARP main studs for the most part will clear the upper oil pan, but the last two on the drivers side (if you're looking at the motor while on a stand with cylinders pointing down) will not clear the upper oil pan. You can trim these down.
mynameisjonas
Perkasie PA
7-14-2003
are there any crossover numbers for the s13 redtop coilpack part number 22448 50S00 ?
mynameisjonas
Perkasie PA
7-14-2003
| « Re: (s13sr20chris) | 8:01 PM 1/14/2005 |
does anyone know where i can get the fuel injector orings shown in the picture? what i need is the one with the red rtv sealent on it
RobDET
Cars
Long Beach Mississippi
5-7-2003
Just did some playing with oil drain plugs. For the redtop SR20 with a stock oil pan the 93 Sentra SE-R plug DOES NOT WORK. (it didn't for me at least)The one from the 93 240sx (Ka24de) works great. It's the same part as the NA 300zx from the same year. (Maybe the turbo 300 too but i didn't look at the part number) Also i just did a head rebuild and the exhaust valve guids and valve seals are not the same as the SE-R either. I had to get mine from JWT. I'm sure that's on the list somewhere though.
RobChanging Honda owners lives, one ride at a time.
Hijacker
240SX Moderator
Olney IL
8-13-2003
all of the trans plugs for a KA tranny should swap over. In fact, I just recently put a 95 S14 reverse sensor into a redtop trans and it worked.As far as timing chain goes. Everything will cross over that is in the FWD SR chain kit. The only part that will not work is the exhaust cam. The FWD SR drives it's distro off the rear of the exhaust cam whereas the RWD SR drives it off of the cam gear. I had to reuse my exhaust cam gear when I did my chain a few weeks ago.
deathBooster
240sx under construction
NEwark de
9-22-2004
| « Re: SR20DET parts guide (Movingviolation240) | 2:10 PM 3/7/2005 |
Need to know which is the correct oil dipstick for the SR20det??? my motor come with a wrong one.. I was pooring 6-7qt in my motor help...
RobDET
Cars
5-7-2003
Dipstick...http://srownersclub.com/Mercha...EMENG Don't have a PN sorry
noodl35
11-25-2003
anyone know the part number for the sr20det crank sprocket and the keyway that goes in it?
Onizuka
91 coupe w/s13 SR20DET 89 hatch w/s14 SR20DE
Southeastern PA
11-6-2002
| « Re: (SpeedRacer1) | 9:25 AM 3/17/2005 |
| Quote, originally posted by SpeedRacer1 » | 180SX Jan 91-Aug 96 AY040-NS929 180SX Aug 96-end AY040-NS041I hear the Altima front brakes are similar or the same size as the larger JDM S13 brakes. But the part numbers arent the same. They are actually the same pads used on R32 GTS-T's not that that helps at all. |
Really? R32 GTS-T's use 300zx calipers, or at least the set I have look identicle to Z32 calipers.
civicsi2
OR
11-13-2004
how about PCV valve?
| First 1 2 3 4 5 6 7 8 > Last |
