 Tire FAQ
Exar-Kun
2005 350Z
Georgia
9-27-2002
  Tire FAQ
The New Tire FAQ sticky!!!! W00t!
The Tire Rack Home Page
Good sources for information on The Tire Rack Website:
Tire Rack Tire Guide
The Tire Rack Tech Center
Tire Rack Tire Test Results
Tire Rack Tire Survey Results
Tire Rack Winter Guide
Tire manufacturers web sites
Advan (Yokohama Japan)
Bridgestone/Firestone
BFGoodrich Tires
Continental
Dunlop
Falken
General Tire
Kumho
Michelin (MAST)
Pirelli
Toyo
Yokohama
Other useful links and things:
Tire calculator (O.D., etc)
How tires work, construction, etc.
GREAT asphalt tire info, Pressure, contact patch and other wonderfull information
Tire 'Bible', lots of good info
Yokohama's explanation of multiple tire and wheel concepts, great reading
Tire pressure info
How to set your "Base" tire pressure (see below for more information as to why that’s important) for performance, and how-to read a load index, tire sidewall, etc.
http://www.j-body.org/forums/r...26864
Good posts about suspensions and wheel tire package affects on track handling.
Other links soon- keep checking back.
Why do people recommend wider tires? Don't wider tires mean more grip?
In a short version, no. Don't go e-mailing me about how wrong I am yet, either. Think about your tire as a balloon (more accurate than most people think) holding the weight of your car up. Now, if you place a balloon on the ground, it has a certain area that contacts the ground, this is the 'contact patch', now you can make the patch wider(wider balloon) but the total rear remains the same, because the pressure on the balloon is the same.
Now, what does this mean to YOU? It means that since the same amount of tread is in the contact patch area between either tire, 'grip' should be the same. Thusly, the only things affecting grip(since the area of potential contact is the same) are tread design and friction(tread compound).
Unfortunately it is not that simple. A wider tire does have some benefits over it narrower counterparts, with a wider contact patch comes a bit better lateral stability(to a point, lateral stress doesn’t vary THAT much between narrow and wide tires), but sacrifices some ride comfort, and less noise cancellation(in theory).
Something else to consider:
Think of a gap in the road surface, typically these run perpendicular to the tires contact patch. On a narrow tire, with a long contact patch, the gap in the road surface would take up more (percentage wise) of its contact patch than a wider tire. Make sense?
...so wider tires do provide some benefit, to a point. Wider tires usually come in stickier compounds, too. Yet, the compound and tread design has far more to do with tire grip than the size.
Now quit asking me how wide of a tire you can fit on something.
Tire options:
See above links for Tire Rack Test and Customer Survey Results!
"best (lowest) price" and "best performance" NEVER go together.
Extreme case: formula one tires cost 900 dollars a piece.
-Kumho's are what I consider a "well i wanted big wheels to LOOK like I wanted to go fast" tires. They stick decently, and roll like complete *** unless you very carefully index them. 9/10 people who acclaim kumho's have JUST upgraded their wheel/tire package from a H-rated to a 17" or higher Z rated.
But hey, they are cheap. For the cost minded person with a high-performance tire size selection. Note, the 712 are the primary reason for complaints, the MX's seem to hold up quite well, and are a good bang-for-the-buck summer tire.
UTQG's:
Ecsta MX: 220/AA/A
Ecsta Supra 712: 280/A/A
-Michelin Pilot Sport/Sport all season (a/s) provide excellent overall grip, and are very linear at the limit (give up grip preidcibly), although not as grippy overall as some tires in their class, tend to wear a bit longer (especially the a/s) and be quiter than most 'max performance' tires. Also rather expensive.
The MXX3 is a dry tire, provides excellent grip, but suffers lack of rain traction and wear, great "summer" tire.
UTQG:
Pilot Sx MXX3: 140/A/A
Pilot Sport: 220/AA/A
Pilot Sport A/S: 400/AA/A
-Michelin Pilot Sport 2 (PS2) provides an ever greater level of grip than the origional Pilot Sport, and aces even the s-03 in some test of overall grip. Featuring a twin compound asymetrical design, it provides ample water shedding abilities with phenomian grip, and a progrssiveness only found in large tread-block asymetrical tires. Fantastic summer tire, overall, the only thing it lacks? A lower price.
UTQG: 220 AA/A
-Pirelli Pzero Asymetrico/Pzero family- great grippy tires, wear out kind of fast, provide excellent cornering grip, and very good rain traction, given that the original asymmetrical was a "dry" tire. The 'rosso' was designed to limit the noise associated with the worn asymmetrico and provide better rain traction, although it gives up some overall grip. The "Nero" version provides a good blend of styling, performance, and costs less than the previous two Pzero tires. the ASym. and Rosso tend to be costly tires, while the nero(not quite as linear giving or grippy at the limit as the asym.) tends to be less expensive.
UTQG:
Pzero Asym: 140/A/A
Pzero Rosso: 240/AA/A
Pzero Nero: 220/AA/A
-Pirelli P7000 and p7000SS: provide good grip for the price, provide good wet weather traction, but again do not grip as well as a "max performance" tire because they do want good rain, and in the case of the SS, light snow traction.
UTQG:
P7000: 160/A/A
P7000 SS: 320/A/A
-Falken Azenis- Great dry grip tires, good for occasional autocross due to its large tread blocking, but all season and rain traction suffer considerably. Noise also becomes an issue as the tire wears. Wears quite fast due to it emphasis on dry grip. NOT a good all-season tire. Very cost effective.
UTQG: 200/A/A
-Falken Ziex 512- the successor the 502, provides a good, V or Z rated tire in most sizes with good all-season traits. Slightly better ride characteristics than KUMHO tires. Wears decently for a V/Z tire.
UTQG: 360/A/A (in V rating)
-BFgoodrich G-force KD: DRY DRY DRY DRY DRY DRY. don’t even think about using this tire if you plan on running these tire in lots of rain or inclimate weather. given that, its a wonderfull dry grip tire, as was its purpose, can be babied through light rain and be OK, but choosing the KDW(dry and wet) would be a better choice for wet-weather excursions/daily driven cars, while providing a good level of grip, price is intermediate, and sometimes very high compared to similar, and possibly better tires.
UTQG:
Gforce KD: 200/AA/A
KDW: 300/AA/A
KDWS: 300/A/A
-Yokohama AVS sport: I have put more than a few sets of these on Porsche’s, Lotus esprit twin turbo, etc. everyone loves them, for the money its a wonderful sports tire, very good rain traction, but wears out quickly, and sometimes becomes noisy after 3/4 of the wear are gone. Good max performance tire for the money.
UTQG: 180-200/AA/A
-Yokohama AVS ES100- similar to the pilot sport, without the steep price tag, recently tested them on a maxima, the wet traction was very good, although not as forgiving at the limit as a Pzero or similar, it costs half as much, and should wear better. Slices the dry/wet/tread wear criterion very well.
UTQG: 280/AA/A
-Yokohama Parada Spec-2: decent tire, design is similar to Falken Azeni's. Only problem I have seen is tread wear and lack of serious rain(downpour) traction. Does not deal well with heat, it does get slick quickly when overheated. Definitely a solid choice for the money if you don’t see snow or heavy rain much, or for show purposes.
UTQG: 300/A/A
-Dunlop W-10 or FM901- good cost effective tire, problems with noise may throw some people off. Wet traction and overall grip is often sporadic. ON balancers it can spin funny, as I have seen many come from the factory (like kumho's) shaved or very badly out-of-round (no tire is absolutely round). In the same area with Falken and Yokohama as far as price, provides adequate traction, pretty good tread life given the price and speed rating of the tire.
UTQG: 200/A/A
-Goodyear GS D3- brand new design, only put one set on a ws6 trans am, guy said they are good cornering tires, but a bit noisy compared to his Bridgestone 730’s he had before. That’s all I can really tell you (no hands on with these yet).
UTQG: 280/AA/A
-Bridgestone Pole Position S-03: bad-*** max grip tire, has two separate tread compounds in the tire, so the amount of grip stays the same as the tire wears. very forgiving at the limit, large water channels provide good wet weather capabilities(put a set on a 540i and an m5 both love them) tread wear is not especially good(12k+ would be good out of these, similar to the Pzero) but does provide excellent traction in both wet and dry. Possibly noise problems as the tire wears down.
UTQG: 220/AA/A
WHEW. I think that covers everything; if you think of one I forgot, let me know...
Here’s my personal ranking (given my experience) if cost is a serious consideration And you need decent tread wear:
1. Yokohama AVS-ES100 (depending on size/weather area)
2. Pirelli Pzero Nero
3. Falken ZIEX 512/Azenis
4. Kumho Ecsta 712
if cost is not a big consideration
1. Michelin Pilot Sport 2 (PS2)
2. Pirelli Pzero system (call Pirelli about this, its direction fronts, asy. rears) or Pzero's all around (matching)
OR: Bridgestone S-03
3. Goodyear Eagle F1GS-D3 (great wet weather grip, some odd tread squirm, but commendable grip and balance)
Yokohama AVS sport(close tie, but noise knocks it down) or BFgoodrich G-force(great grip, rain and noise problems)
All in all, you got to figure out what tire matches your driving styles and car/suspension setups. Be realistic. Don’t go buy a G-force KD (or Falken Azenis) if you KNOW your going to be in serious rain or snow. Get something more snow/rain capable.
I myself have Pirelli Pzero's and love them to death, I have had other Pirelli’s, Michelins, etc on my cars and these are the best yet (have not had s03 on my car) but they come at a price. They do require a warm up to get to a good grip level though.
Tire Inflation Tips for Road or Autocross Racers
1. Inflate your tires to your desired pressure (IE 30-32psi baseline usually).
2. Mark each tire from the outer edge of the tread block (outside edge blocks) to about 1" down the sidewall of the tire. I suggest using a white grease pen.
3. Do your lap, run, etc.
4. Check to see how much of the grease mark has worn off.
-if LESS than 1/4" is worn off, deflate your tires a few PSI
-If between 3/8" and 5/8" is worn off, remark the tires.
-if MORE than 3/4" is worn off, inflate the tires a few PSI.
Remark the tires and write down the PSI you set them at. Ideally you'd get about 1/2" rollover during hard cornering, maximizing contact patch. You may notice different tires (Front to rear usually) require different settings of air pressure to run effectively, that’s fine just adjust them and keep checking.
Trouble shooting tire symptoms at the track
Troubleshooting Tire Temperatures
Reading - Handling problem - Reason
All tires too hot - * - Compound too soft for track and ambient temperature conditions.
Front tires too hot - Understeer - Front tire pressures too low.
Rear tires too hot - Oversteer - Rear tire pressures too low.
Inside edges too hot - Too much body roll - Too much negative camber or too much toe-out.
Outside edges too hot Too - much body roll - Too little negative camber, too little toe-out or too much toe-in or wheel width too narrow for tire width.
Center of tread too hot - * -Tire pressure too high.
Edges on too hot - * -Tire pressure too low.
All tires too cold - * - Compound too hard for track and ambient temperature conditions or car not being driven to limit.
Front tires too cold - * - Inadequate load on front tires.
Rear tires too cold - * - Inadequate load on rear tires
Remember to set your cars pressure back to normal after the event if you use street tires (street tire class, etc).
You'll probably notice quite the improvement in cornering using this method....
Tire Maintenance Tips and General Information
Tire Terminology
Directional - The tire has to rotate in one direction, in respect to the vehicle. Directional tires generally feature swept back tread blocks, and use this design for better water traction. Directional tires will have a "rotation" or "direction" arrow specifying how it should be sitting on the wheel and car.
Asymmetrical- The tires tread is different from side to side, and MUST have one side of the tread design/tire facing out, the other facing in. A few tires feature this design, it serves the same purpose as using a directional tread, buy lends itself to larger tread blocks overall (generally speaking).
Tire Care
Rotation - Rotate your tires, supposing they are the same size front and rear, every 4,000 to 6,000 miles. The harder you drive, the earlier you should rotate them, and vice versa. If you have a directional tire, you can only move the tire/wheels front to back, and can't switch sides without dismounting the tires. If you have excessive alignment problems(negative camber), I would recommend dismounting the front tires, and swapping them side to side before the rotation, this will help even out the wear pattern that you see so often(inside edge worn out too early). If you have asymmetrical tires, you can rotate the tires any way you want, but I would recommend a modified cross rotation. The front tires go to the opposite corners, while the rear go straight up(IE LR tire is LF, but LF tire is now RR.), this wont avoid the edge wear(since the tire can only have one 'outward' side) but it will help extend the life a little bit by avoiding repetitive suspension stresses(wear patterns). All other tires you can rotate as you want, usually front to back, as normal.
Tire Inflation
See above post and FAQ link about tire pressures. Check your tire pressure at least once a week when the tires are cold to make sure you aren’t running one under-inflated.
Leaky tires?
In the case your tires do not hold air, getting them "dunked" to find the leak is a great idea. Typically most tire shops have a small tank with water in it to submerge part of the tire/wheel to see where air is leaking from. If its in a fixable area of the tire, it should be PATCHED, not plugged. Plugging a tire does not reinforce the belts, or keep the belts from getting moisture or other things in them. Needless to say the 'patch-plug' is the best method. A patch-plug is an item that looks like a mushroom, where the 'hat' is a patch, and you pull the 'stem' through the hole in the tire to seal it completely, inside and out. This is the only way to repair a tire safely according to Michelin and most other tire manufacturers. Be cautious with patched tires and high-speed driving, some manufacturers do not warranty, or ensure that even a properly patched tire can handle the original speed rating of the tire(EG H, V, Z, etc) because most of the time, the patch itself is not designed for such stresses. Just a thought…
Stages of tire wear
Most tires start with 10-11/32" of tread all across the tread blocks. In between the tread blocks you should see some little "bridges" of rubber, those are "wear bars" once a tire's tread is worn to those, its time for replacement(most wear bars are at 2/32"). After the wear bars, you will hit "secondary rubber", which is a rubber cap below the main tread carcass, you will know it by a slight discoloration compared to the regular tread rubber. After that, you'll hit your cords, or the inside of your tire...we all know what that is. Check your tires wear every week(with your tire pressure), and at worst every month, and be sure to check the inner and outside edges for odd wear, just because the middle of the tread is fine, doesn’t mean the tire is.
*Remember*, no matter how good your engine, suspension, brakes, differential or anything else is...the only thing keeping YOU in contact/control with the road are your TIRES. Don't under estimate their importance.
-Chet
-thanks to: 240_keyy and Big Jon for links, etc.:thinker
You can live in a car, you can't drive the house.
"The essence of stupidity is doing the same thing and expecting different outcomes"
-Albert Einstein
"It is possible to store the mind with a million facts and still be entirely uneducated." Alec Bourne
2005 Daytona Blue 350Z 6 speed. NISMO Exhaust, NISMO Differential and PS cooler, JWT intake, B&M, Redline 10W30/MT90, Tomei 2 way LSD, DC headers, Comp Clutch flywheel and stage 2 setup, SPL Front upper arms, SPL rear toe link, TEIN Flex coilovers, Stoptech 355 F 328 R BBK, ARC rad panel, ARC catch can, Carbing STB, HKS DLII, ADVAN Super Racing V.2 18x9 F 18x10 R with ADVAN SPORT 255/40YR18 F 275/40YR18 R
pr1m021
oak ridge nj
11-12-2008
 « Re: Tire FAQ (Exar-Kun)
whats the best all season tire for under 90 bucks?
paposalsa
2006 350Z
Melbourne Florida
8-13-2008
I found this concerning asymmetrical tires. So I'm confused about with your post above.
http://www.justtires.com/services/faqs.html
Mounting
My asymmetrical tires were mounted incorrectly. What should I do?
Asymmetrical tires are designed to improve handling and reduce noise. These tires can rotate in either direction with the correct side facing out as indicated on the sidewall. If installed with the wrong side facing out, the tire will not provide optimum performance. However, no damage or premature wear to the tire will result. Simply have it dismounted and reinstalled correctly.
freeform
2007 m35
beaufort sc
7-26-2009
how is the bridgestone re11 ultra
okisrniju
180SX (SR20DET)
Okinawa Japan
7-29-2009
Personally, I like the Federal RSR's up front
» Return to Nissan Tires, Wheels, Brakes and Suspension
