stock wastegate pressur?
audiman
Hy
Anyone knows the stock waste-gate opening pressure of a S14A sr20det? I connect the waste-gate hose directly to the boost-pipe / charge pipe.
I have some problems whit controlling the boost whit my AVC-R. So i disconectit the AVC-R. Then i connect the waste-gate as described above but is is boosting at 1 bar (14PSI) at 4800revs then i let off the throttle before it over-boost.
Roy
zach-Ka
Car: 1990 240sx (SR)
Stock is 7.5 psi I believe. Do you have the controller hooked up correctly?
audiman
Yes the controller is hooked up correctly. But whatever we do its always over boosting past 4000rpm. So to see of the wast-gate and/of acculator are oke i connectit the wast-gate acculator directly to the chargepipe/hotpipe/boostpipe whatever. As far as my turbo knowledge go's i only see the amount of boost as set by the wastegate spring. But is still overboosting after 4000rpm. The waste-gate is good and moves free. So i think the wast-gate acculator is broken?
zach-Ka
Try hooking the waste-gate directly to the hot pipe with no controller, and see what psi it runs. If it goes past 7.5 you know its a faulty actuator.
audiman
Yes I did it. Is over-boosting to 15PSI and gos up until i go of the accelerator.I sems to by a broken actuator
I have a actuator of a CA18 t25. Anyone knows of it wil fit a SR20det t28?
zach-Ka
Awesome!I don't know if using a t25 actuator on a t28 will be safe. You can try it though... Its not gonna be any worse than it is now.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Get an HKS actuator and call it done.
Morph
Car: 91 Sr Powered Coupe
zach-Ka wrote:Awesome!I don't know if using a t25 actuator on a t28 will be safe. You can try it though... Its not gonna be any worse than it is now.
HA i was just researching this there shouldnt be any issue, AFAIK both are around 7 PSI. You will need the moutning flange thing from the t28, and it will bolt right up.
OM3GA wrote:Get an HKS actuator and call it done.
125 dollar fix vs free? Common. lol
I did it though, and i was digging around the garage for a funnel and found my old blown t25 and actuator...ya i was pissed.
