i have seen many posts here regarding the fuse locations on the interior fuse box, and requests for diagrams..ever ones response is the same " check the FSM" - reason people do this is to force others to actually research thier vehicles and make at least a half a$$ed atempt to find out on thier own..
well let me help out a few fellow noobs to this forum then:
for interrior fuse box diagrams do the following:
go to the FSM- http://www.nicoclub.com/FSM/
choose your vehicle
select the EL.pdf file and choose the " power supply routing" section and print it..it should be a chart listing out different routes with numbers and fuse amperages next to them
then select the foldout.pdf file from your FSM and choose the " fuse block-junction box" section, should just show your fuse box with a bunch of numbers and print it out..
these are your wires, fuses, electrical mumbo jumbo..
compare the 2: you will figure it out & if you cant, maybe you should not be working on your car yourself..
Your Welcomed,
