--bigtime wrote:I had both cats removed from my 94 Q45 and replaced them with a straight pipe. A couple of days later the engine started missing occassinally like one of the coils was going out. Could this have been caused by the cat removal?
Call your dealer up and ask then post back.DrivingMyQ45IntoTheGround wrote:as far as the 1400 cost for each cat goes..that's a bit far fetched to say the least.
Lots of precious metals indeed, i dont disagree with you there.. but search for oem replacements not coming from a stealership and the average range is 340 a pop.maxnix wrote:Call your dealer up and ask then post back.
They were $1100 form Joe over a year ago. Lots of precious metals in the Infiniti converters, which is why they last 20 years if the engine is maintained.
Modified by maxnix at 6:37 PM 3/16/2010
Aftermarket junk wih few precious metals should not be confused with OEM value with more precioius metals and better construction, especially with reard to converters.DrivingMyQ45IntoTheGround wrote:
Redline S1 is the best product on the market because of it's high content of PEA. Gumout Regane used to have PEA but it isn't listed on the msds anymoreoldmako wrote:In the 2 years I've owned mine, any misfire issue is usually cleared up by running good gas through it along with some fuel system miracle jizz. Since I travel like a mofo I am unable to refuel with one specific brand of go juice. I am also exposed to who knows what's in a particular stations tanks. IOW, I would doubt that the cats would be the culprit, but perhaps those mothers have plenty to do with back psi and all kinds of funky stuff is about to happen to your car as a result of their removal.
As far as the MJ, I used to run BG44 but no more. Now it's usually techron simply because it's readily available. I read something here about another product being superior but my feeble brain has been so severely taxed and abused over the years that just matching my socks has become a major brain drain. In fact, it took me 14 tries and 50 minutes just to type this message.
Hey, I just noticed that it's MARTINI TIME!
