Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Mar 13, 2010 3:28 pm
Every Nissan dealership was required to purchase at least 1 most have 2-3 for use by technicans [the earliest ones cost $4,000 US each, later one are all intergrated into a Panasonic lap top with accesories they cost $8,000.
Search around for a Nissan OBDI adapter to serial or USB cable then find software...............which will emulate about 1/2 of what Consult does.
Normally one looks at MAF voltage vs injector open time in milliseconds to calculate how much fuel per squirt is flowing4 squirts per rev x 2,000 = 8,000 squirts per minute or how much fuel per mile/minute.
Anything above 1.6 milliseconds is too much cruise fuel. WOT high [4,000>7,000] rpm is ~ 10.5<9.5 msec.
The dead time on an injector is the first 0.7 ms so mass only flow in the next 0.9 [for 1.6 msec].
So 0.1 msec is about ~ 1% so easy to calculate 10% would be an extra 0.9 ms.
The only thing besides a fuel leak that can increase injection time is TPS error, MAF error, or coolant temperature error signal.
