My argument was that multi-core processors evolveD due to need. Not that that is still the case. That said, TomsHardware's benchmarking of the 980X and 975X (975X is quad core and 8MB L3 cache and 45nm but other than that almost identical to the 980X) shows some definite gains in certain areas. So, yes, depending on what you do with your machine, you may "need" 6 cores if you're in need of a performance boost. It isn't really a cost-effective upgrade for gamers versus serious video hardware until the price drops, though.RCA wrote:So much for that argument of "processors evolve because of need".Are people really in need for a 6 core i7?
Awesome news none the less. I have heard rumors that the 980X would be a i9 but yea can't wait to see the bench marks.
Ahh, I see. My apologies MoD.MinisterofDOOM wrote:
My argument was that multi-core processors evolveD due to need. Not that it is still the case...
And, like I said, the extra cores aren't the only benefit. More shared L3 cache benefits everything you run, even if it only uses one thread.
L3 (or L2 or L1...L stands for level, to differentiate the different successive levels of cache memory) cache is a small memory reserve that directly serves the CPU. Processor cache can become a choke point if memory throughput is below the processor's actual data-handling capability. So more cache memory is always better. But at the same time, with on-die (faster than off-die) cache, space becomes an issue. There's another place where the new 32nm process helped fit a lot of chip on an existing die.The L3 cache is shared between ALL cores. So there's a benefit as far as memory goes when processing on fewer cores.RCA wrote: Ahh, I see. My apologies MoD.
Quick Q, what is L3 cache's job? I have read this term a lot but wasn't 100% sure what it is.
Right... I take it you have never used more then one monitor?chemao wrote:Pointless unless you run applications that are ridiculously multithreaded. 99% of what you do won't even touch the 3rd core.
Xeons have features that servers use. One of the biggest being support for ECC memory. This is almost never found in desktops so it is not included in the consumer varients. There are a few other features that I can't think of though...RCA wrote:Hey what's the deal with the 6 core Xeons?![]()
They are more expensive than the i7 980Xs
http://www.theinquirer.net/inquirer/rev ... enchmarked
Same reason you can go buy a Dodge Ram or a Sterling Bullet. Most people wouldn't know a Bullet if it bit them in the face. But it's there. Different markets, basically the same product. Sterlings come with commercial-grade support, which means better hours, less downtime, as necessitated by the business world.RCA wrote:Well they have mobos for Xeons and Apple sells desktops on them so why would one person buy an i7 over a quad core Xeon."
