Same trans code, same dimensions, different gearing.motoman399 wrote:i wonder if the gearing is the same as the 240sx trans. post up results when your done
OutToWinPAHC wrote:Same trans code, same dimensions, different gearing.
OutToWinPAHC wrote:240sx trans
FS5W71C3.3211.9021.3081.0000.759
Nissan truckFS5W71C 3.3211.9021.3081.0000.838
hmmm for sure not in the area. but i would think you could get a busted trans for a decent price somewhere around your area. but if you do end up getting rid of it, like i said i need some parts lol. and i would take the syncros alsorsagen wrote:its ok im sure this cross member will work if anything. and its a different size so im sure a regular one wont work anyway.
and motoman339 u might just get it if your in the area cuz either im buying another transmission (240sx not a dam truck). if i cant get my hands on a transmission im scraping the car, cuz im done if so.
dam im pissed. i f***ING HATE BEING MISINFORMED.
OM3GA wrote:wtf this is so weird.
I would of went down and rented one but i live out in the middle of no where... (not really but noone in town rents those) so the next best thing was a air chisel.darens13 wrote:i just used the at crossmember, but i only got it to work with 2 bolts holding it instead of the 4. next time you pull out a pilot bushing go down and rent a blind hole puller tool. it took me all of about one minute and that sucker was out. nice progress, dont get discouraged!
Thanks for the infobreadbox wrote:The piece under the taillights, needs an 8mm deepwell socket, and remove all the bolts under the tali lights the third nut down(bottom one) on the out side then remove the nuts on the extra long bolts. Then it comes out.
ILoveMyRHS13 wrote:Why not just use an SR trans with a KA bell housing if you want a shorter 5th?
I dont think i can find a sr transmission, and i really dont care about the shorter 5th thats just the transmission i found for the right price.ILoveMyRHS13 wrote:Why not just use an SR trans with a KA bell housing if you want a shorter 5th?
Thanks. parts in this area are pretty hard to come by. they had to order the clutch for this transmission from ontairio, and i live in alberta.iRides13 wrote:You've got a great car in good condition. you've made progress. just save up a lil cash and keep looking around. ILoveMyRHS13 sounds liike he spoted your best bet. look around for part outs!
thats true hard work does pay off. all im waiting for now is for a punk kid to slid one into a power pole so i can have the parts sounds mean i guess but thats the only way.whyteboi wrote:DONT GIVE UP
search and search and search, youll find a 5speed 240 transmission somewhere for not much. i searched untill my eyes bled and i got my swap for $250 and just $145 more for a new exedy kit.
you wont regret ur hard work
