C2CAHOON »
https://forums.nicoclub.com/c2cahoon-u156413.html
Thu Mar 18, 2010 12:29 am
your grounding issue seems to either be a weak battery or bad ground, stop by a local autoparts store and see if they'll test your battery. If it tests good i reccomend using a wire wheel or brush to clean the area around your grounding cables in the engine bay and battery, also make sure your using a sufficient size power cable to your engine bay, and consider adding another grounding point ie a good grounding strap from the engine block to the chassis
