if you're trying to put s15 hLSD in your hicas R200 diff housing, it can be done. You can still use the vlsd cover for more oil capacity too
If you use an s15 rear cover because u have one (why), the cover will bolt on but the diff wont bolt up to the s13 subframe.
swap internals, use the same cover. If you wanna downgrade to the non hicas cover i'll trade ya, but both will work great hahaha.Make sure you buy the 6bolt s15 output shafts for the hicas diff. They'll bolt right up to s13 axles.Have fun with extreme grip at no cost of extra understeer!
