shiro_neko »
https://forums.nicoclub.com/shiro-neko-u152359.html
Sun Mar 07, 2010 2:23 am
Im currently troubleshooting my slight hesitation high idle problem. I have done some checking and cleaning and Im in the point of checking my EGR. My EGR is not functioning so I tried testing the EGR valve and the diaphragm lifts when I suck on the vacuum hose. So I checked the vacuum hose to the BPT and no vacuum is present when racing the engine. Then I tested the EGR control solenoid and this is where Im confused.
I measured the voltage of terminal a (lg color) and its 0.8v at idle and battery voltage while racing. But the 89 FSM says its the other way around. However in the "Electrical Components Inspection" section its 0.7-0.9v engine running and battery voltage engine running (racing)
Furthermore, in page EF & EC 149, its illustrated that air passes in vacuum lines going to BPT and P.R. solenoid when 12v current supplied, and air passes in lines going to BPT and intake collector when there's no supply.
To make my post longer, its also weird that there's no vacuum when I check the line coming from the Intake collector weather its in idle or not. If I understand this correctly this is the vacuum that supplies the line going to the BPT then EGR valve. Even though the signals might be reversed I should have a vacuum in one of the conditions.
