esahuque »
https://forums.nicoclub.com/esahuque-u20709.html
Sat Mar 06, 2010 8:29 am
My car was smoking on start ups real bad. did a compression test and all looked good (160 all 4) with low compression pistons. so it had to be valve seals. changed all of them with the head on the car. It went smoothly . It smoke when i started it up the first time after i replaced the seals, which was expected. But i have driven the car about 4 times over a course of 2 days now and its still smoking (not as bad) on start up only, once it warms up it goes away. How long does it take for all the oil to burn up after i replace the seals? I'm going to run some seafoam through the gas and intake to see if it helps clean it out. has anyone changed their leaking seals before and how long did it take to clear up? what did you do to get all the oil out the manny and exhaust system?
