myview »
https://forums.nicoclub.com/myview-u155546.html
Fri Mar 19, 2010 1:13 pm
Dear Mr. goody90q45
Thank you very much for your advise before.
My mechanic replaced two injectors (#1 & #7) and the car ran smooth, but could not be able to accelerate more than 30 miles per hour. I parked after driving 15 minutes and then 3 hours later I drove again. This time, after driving 5 minutes I smelled a lot of gasoline from the engine and same time the engine ran very rough. I drove to the mechanic, then the engine stopped and couldn't restart. Next day, I've found from the mechanic's assistance that #1 injector's chamber was completely flooded. The mechanic cleaned the chamber, and replaced with new injector again, then the car became normal. He showed me #1 injector and said looks fine (no O-ring damaged according to him), but to be safe he replaced with new one again.Everything seemed and sounded fine this time, but the car is not accelerating fast enough speed. The car became much slow to pick up the speed. For example, driving at 30 mile then stepping on the gas padel won't accelerating fast enough, it slowerly accelerating but the RPM shows high. The car eventually speeding at 40, 50 .... miles, but slow to pick up that speed.I've never had this problem before changing the fuel injectors this time.Spark plugs are all new; replaced two months ago.
Dear Mr. goody90q45,I would like to know what could went wrong at the first time and what could be the problem now not accelerating fast enough.
This is my first time dealing with this mechanic. I am not so confident about his skill and expertise.
Would you please give your opinion and advise.
Thanks so much!Peter
