i have an exhaust question????
Discuss topics related to the VQ series engine.
Jereme329
Car: 2000 Maxima
ok the guy that had my 2000 max before me cut out part of the y pipe, there is no cat and no intermediate pipe. the smart guy just welded in a straight pipe and unpluged the O2 sensor. my exhaust smells really bad, when i go to take off if im not over 3000 rpm then the car will die, sometimes it sounds like there is a backfire in the intake manifold. if i change my whole exhaust and get a high flow cat and the O2 sensor would this solve my problem? here are some pics of my exhaust.....
altima4me
Car: 2005 Altima 3.5 SL
AEM CAI, Magnaflow cat-back, grounding kit, Bose 6-disc, Xenon HID, 4000k white fogs
I think your problem stems from the O2 sensor not connected. The smell concerns me, like a possible leak in missing cat area. The Nissans are touchy with sensor issues. You might start with fixing the y-pipe first, then add your other exhaust mods.
audtatious
At a minimum you need a bung added for the O2 sensor. I assume you have a constant SES light as well, if not then it's blow or the bulb has been removed as you will be throwing codes all over the place.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
install a bung, reinstall the 02 sensor and see if the smell goes away, theres unburnt fuel comming out of the exhaust thats what stinks
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
