Heat Question!
Indy_Spoolin
Car: 1990 Nissan 240sx SE
Ok so im new to the Nissan game! Bought a 1990 Nissan 240sx SE the other night for next to nothing! This is the first Nissan I have ever owned. And I love it! The car has very little heat even with the heater on full blast. Anyone might know what is causing this? All help is greatly appreciated. Will post pics up tomorrow! Thanks
samxini
Car: '95 240sx w/Kouki conversion
You probably need a new heater core
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Heat is about the same on all cars. Could be a clogged / clogging heater core, clogged line, bad t-stat, or an unbled system.
Start the car run it and blast the heat. Let it run a few minutes and then check both of the heater core hoses. Touch both of them see if one is cold or not, if it is its most likey the core or hose.
Indy_Spoolin
Ok I will check the lines today while im at work!! I will keep you updated!
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Does the engine regulate it's own temp pretty well? if not the t-stat may need replacing.
Indy_Spoolin
yes i dont have any over heating issues at all!! where are the heater core hoses located so that i can check them?? thanks
Justin35ll
Car: s13 coupe sr20det
In the engine bay on the passanger side firewall. You'll see 2 coolant lines one above the other both going into the firewall. They're to the right of the A/C lines going into the firewall
Indy_Spoolin
ok thanks im going outside here in a few to take a look!! Ill keep updating as i go!
