mott6904 wrote:I would bet on a connection issues. If the alternator is really putting out 13.1 at idle than that is not your problem.
If the alternator output is at 13.1 at idle with no other load on the system and if you add a load (ie lights, heater,a/c or anyother load the voltage will go down. There is the problem.
Check the battery voltage @ idle and @ 2k rpm It chould be 13.5-14.5.
The voltage regulator adjust the voltage output of the alternator. It does this by montioring the voltage . Remember the 2 small wires that go into the alternator? Those wires go to the following 1 the alt light( Field )and the other one goes into the regulator and that wire is the supplys the regulator with the voltage. And the the regulator adjust the voltage to the load of the system. So it the voltage is at 12.8 volts the regulator will adjust the voltage to keep up with the load. @ 13.5-14.5
But I would check the wiring and load test the alternator.
