Sounds like it was a misfire which was probably the plugs. Would it only die when in park but dip when in drive? I've got the same deal with mine but I think it's the ignition coils which are prone to go bad. I changed my plugs last year.Evak wrote:01 QX4 4x4 w/ 98,000 miles, stock motor, and we've owned it since 84,000. For about the last year or so, when stopped at a red light, the idle would drop from 8-900 to 5-600 RPM. The idle would always bounce back up, then drop again. Since it was intermittent we have not taken it in, and have not gotten any Check Engine lights. Last Friday, when finally taking it into a private mechanic, the truck accually stalled while in the parking lot. It fired back up, then stalled again. I thought it was a dirty MAF, because I have read a lot about that on the boards here. They check the MAF, it's clean, and say if was the MAF, the Check engine light would have come on. So, they change to spark plugs, fuel filter and add some kind of fuel conditioner, and let me on my way. It seems to have corrected the idle issue and truck is running much smoother now. Driving about 200 miles this weekend, I have had no issues with the truck at all. If anyone is experiencing something like this, I hope it helps.
I'm pretty sure IVT kicks in at 2,000 RPM's. I could be wrong tho.523 wrote:... does anyone know at what rpms the powervalves and/or valve timing are supposed to switch?
From what I've seen dude, you're never wrong.Pwnin O’Brien wrote:I could be wrong tho.
I concur, Pwnin's the man! I'd hate to have to live up to his rep, lol.Buzzman wrote:
Thanks. So, it's something like IVT @ 2k, swirl valve opens @ 3k right? I'm not sure how the power valves work or if they have an effect at a certain rpm... I'll keep reading...Pwnin O’Brien wrote:
Swirl control valve opens at 3,600RPM's (2,800RPM's for M/T). Maybe it was a sleeper cavalier? haha523 wrote:
Driving home yesterday, I pull out to pass an old beat up chevy cavalier, suddenly the guy nails it and drops me like a bad habit... no idea why he accelerated but that settles it, my car has no power! So... I just ordered the MAF, and tonight I'm going to check something I read about the swirl control valve getting stuck... my completely unfounded guess is that it may be running out of air at high rpms due to a stuck swirl valve...
523 wrote:Thanks!
Some of the items you mention make a lot of sense... I probably should have mentioned some stuff I've already done:about 1500 mi ago (late 60's mileage) before the hesitation started (but after the idle stalling):- New air and fuel filter, oe replacement- New ngk "Cold" plugs (the ones the manual recommends as "cold")- Throttle body cleaned and ran fuel injector cleaner (the kind you hook up to the fuel lines and run the engine on)- oil and filter and other assorted stuff...- new crankshaft/camshaft position sensor
I'll look at the hoses tonight... see what I find. I heard not many people having luck cleaning the MAF so, even though it's not throwing codes, I thought I wouldn't bother... my order has not been confirmed so I could probably still cancel tomorrow morning. I guess I jumped the gun, but it just sucks when you floor it and not much happens... stupid "Ward's ten best engines"...
LOL...maybe the cavalier was actually a sleeper... I hate sleepers, why can't they just be like everyone else and put big wheels and stickers and everything ... at least a large dia ss exhaust so I can spot it as it speeds off and say to myself "well, that thing probably has a twin turbo LS6 swap, so it's ok"
I don't even want to think about powervalve screws... maybe if I don´t think about it it will go away.... j/k... the loctite fix will happen sometime within the next couple of months, since I won't be driving the pathy much.
Thanks again, that's a lot of valuable info!
