1995 Driver Window Button
fun240
Car: 95' S14, 91' NX1600
This thing is so impossible to find.. Mine has finally broken completely, and I cannot even use the window. Everything electrical wise works except the button itself
Unfortunately, the pin combo/wire combo is different from any other model, so that rules that out
Any alternatives? Lol
Caveit77777
Car: 1996 240sx SE
Same thing happened to mine I think. The passenger window won't go down unless I do it from the driver side.
fun240
Ya it sucks man. I wish it was my passenger window lol
Anyone have any ideas?
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Maybe the contact inside the switch assembly broke. Did you try swapping the switch out already?
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
fukin240 wrote:Any alternatives?
check classifieds all day every day and jump all over the first one you find. it's what i had to do to find one.
Lev_96_240sx
Car: 96 240sx
If nothing else works and you still want one you can always get one from courtesyparts.com for $236 (driver side power window/lock switch)
scotty-2-forty
Lev_96_240sx wrote:If nothing else works and you still want one you can always get one from courtesyparts.com for $236 (driver side power window/lock switch)
$236?! Did I miss something?
numbnuts240
2011 Ford Focus
2010 Mazda 3
that's a dealer part with a design that was only utilized for one production year. it's the '95 model year's only flaw.
scotty-2-forty
numbnuts240 wrote:that's a dealer part with a design that was only utilized for one production year. it's the '95 model year's only flaw.
Eeesh. I'd just tear the thing apart and attempt a DIY fix at that rate!
Funano
Car: S13 240sx hatch w/sr20det "the black mamba"
Damn. When I was looking for my car every 240 in my local classifieds had a bad power window switch. Can no one order food at a drive-thru anymore??
numbnuts240
2011 Ford Focus
2010 Mazda 3
i tried that once too lol. didn't work.
Funano wrote:Damn. When I was looking for my car every 240 in my local classifieds had a bad power window switch. Can no one order food at a drive-thru anymore??
i go inside
scotty-2-forty
numbnuts240 wrote:i tried that once too lol. didn't work.
Hahaha ... well, worth a shot anyway. Besides, you're probably just like me in that we love taking things apart just to see what's inside ... in other words, for the heluvit!
numbnuts240
2011 Ford Focus
2010 Mazda 3
pretty much. while i wait for a cherry picker, i think i'm going to disassemble the carbs i took off the datsun for s***s and giggles.
Lev_96_240sx
Car: 96 240sx
You may not like the price man, but that's what I saw when I looked it up today on courtesyparts.com. In fact all the S14 driver side switches are that price, and they vary from zenki to kouki as well as from base to se models. Taking it apart may work, idk, never tried. Mine is on its way out as well.
numbnuts240
2011 Ford Focus
2010 Mazda 3
so a 96 with power windows and locks has a different switch than a 97 or 98 with the same options?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
As far as i know the switch is the same from 96 through 98.
numbnuts240
2011 Ford Focus
2010 Mazda 3
that's what i thought.
maxima0-60
Car: 95 Zenki SE
i just open my whole door hahaha
scotty-2-forty
That kind of price is robbery. I could refit the car with manual windows for less! Correct me if I'm wrong, but wasn't there a time when everything Made In Japan was cheaper?
sx moneypit
1986 Toyota MR2
Yeah ,about forty years ago.
scotty-2-forty
sx moneypit wrote:Yeah ,about forty years ago.
Yep.
motoman399
Car: 98' wrecked (RHD coming soon) 240
if you diy it. take apart the switch. then take the rocker part of the switch off, you will see inside it there is a spring and a white piece of plastic. the white plastic rides inside a glide. a part of that glide breaks off. i have not found a way to fix the glide. good luck
scotty-2-forty
motoman399 wrote:if you diy it. take apart the switch. then take the rocker part of the switch off, you will see inside it there is a spring and a white piece of plastic. the white plastic rides inside a glide. a part of that glide breaks off. i have not found a way to fix the glide. good luck
It's nothing a paper clip and duct tape can't fix, lol, j/k! ...... Hmm, wait a minute ...
Lev_96_240sx
Car: 96 240sx
numbnuts240 wrote:so a 96 with power windows and locks has a different switch than a 97 or 98 with the same options?
Not saying that I couldn't be wrong, but as per courtesyparts.com all the different models have individual part numbers. That is a 95 is not the same as a 96, and neither is the same as a 97-98(which are the same part#).
As you can see here:http://www.courtesyparts.com/kb_search_ ... _3727_3731
The difference that I noted is the final digit in the part number, 25401-S1400x (1-6 depending the model and trim level)
At any rate, it doesn't change the fact that the OP doesn't want to spend this kind of money on a window switch (and I don't blame him), just pointing out what I observed.
fun240
THANKS FOR ALL THE RESPONSES
<3
Yes, $236 is outrageous. I guess i will keep checking on the classifieds and so forth.
A 1995 is different from all the rest =(
Thanks for giving information about the item taken apart. I wish there was a way to fix it. Thanks all.
SirSilvia
Car: Sold both my babies
sunroof FTW
motoman399
also i think the 98ish pathfinder has the same switch rocker that would work. i have not confirmed this but when i head out to the junk yard again i will. and subaru's use the same looking switch's as nissan's. like my friends 01 2.5 rs. just throwing it out there.
