pubfinder wrote:it wasnt that heavy, i could pick it up and lift it over my head not that big of a deal, i dont know if yours is the same but its way easier to take the 4 bolts that hold it to the plate that attaches to the frame than the bolts in the frame. straightening it sucks, cause its light tubing... dont know what to do there....
it's not the tubing that's bent... it's the mounting arms... which are flat metal. Right now, the whole front is shifted over enough to push on the right corner light and fender (right where the two meet). the plastic mounting arm of the corner light is broken. So, I'll either have to superglue it or just buy a new corner housing. The fender looks okay, doesn't seem dented there.
If it is indeed Aluminum, then I might be able to straighten it out... possibly even smooth out the part that hit the rock.
I was talking to my friend and we were worried it would weigh like 200 lbs or something... no way I could handle that on my own... unless I use a bunch of rope from the garage ceiling (but moving it around would take forever to do).
But first... I have to take it off... >.>
