240life »
https://forums.nicoclub.com/240life-u76914.html
Sat Feb 06, 2010 6:48 pm
Whats going on guys, I got a SR related question that I can not find an answer to. My friend and I both own S13 blacktop motors, I was looking at another motor-set (also s13 BT) when I thought the T/B and tps looked awkward on this engine and my friends. What I saw was the tps resting on 2 perches and the arm was clearly visible, where as mine is completely inserted into the t/b with no visible moving pieces. I always thought that s13 sr's used the same throttle body. All 3 of these engines are running e5 ecu's and my tps and T/B is clearly different then the other 2. ...I guess what I am looking for is any information some of you might have buried in your heads, because all my research is leading no where, except that I might be running a s14 T/b.
Modified by 240life at 9:08 PM 2/6/2010
Modified by 240life at 9:45 PM 2/6/2010
