Ok, so your car has two resonators. Each one is located right after the downpipe under the driver and passenger seats. Here's a good explanation of what a resonator does from wakopedia (the forum automatically changes the name to wakopedia, I don't know why)...Innovazn wrote:Hey Pwnin, seeing as you know a bit now... im still CONFUSED i want to get an exhaust.... being Canadian i need the cats.... I wanna take everything BEHIND the cats out and do custom exhaust. Deciding on the muffler..... want something that will turn heads... im not too worried about the police either (got nothing to hide and i know the higher ups since i work closely with them) The resonator... im a retard... WTF IS IT ?!!?
... ok if those are "resonators" why the hell is everyone calling those cats? youre takling about the piping coming from the manifolds right? cuz according to smart Nissan we have "4" cats but only the 2 in the front under the driver/pass seat are the cats and the back 2 are resonators right? or am i reversed?Pwnin O’Brien wrote:
"Resonators, also known as Helmholtz resonators are sections of exhaust pipe that expand to a larger diameter and allow the sound waves to reflect off the walls and cancel out. Resonators are mostly used to reduce raspiness and popping. Resonators are similar to an Expansion chamber, only for 4 stroke engines. They do not produce much back pressure.
Many North-American cars (and possibly cars in other parts of the world) made since the early to mid 1990's can have up to 3 distinct (but similar looking) exhaust components downstream from the catalytic converter(s). Each of these components may be called resonators or mufflers. Usually only the last component is the actual muffler, and the other components are the resonators."
So it is almost a muffler, but it reduces raspiness and popping (or that backfiring noise). In other words, it will help your new exhaust NOT sound like a Honda Civic with a fart can. The good new is that the resonators do not create much backpressure, so they don't choke the system. I highly recommend a Magnaflow high-flow muffler and your EGV's will at least be doubled.
If you call your Nissan dealership and talk to a tech, they will tell you the following: your vehicle has two catalytic converters, they are bolted directly to the exhaust manifolds and then after those are the resonators (one for each side). Then there is the muffler (the large 2-into-1 muffler) and then there is the post muffler (the small muffler that hangs down from the back of your vehicle).Innovazn wrote:
what would be the smarter idea? keeping the resonators i would assume... i want my car sounding loud with a low grumble. i just absolutely LOVE rumble... but forsome reason hate the small cars with their screaming whinesPwnin O’Brien wrote:
When you replace the exhaust you should remove the muffler and post muffler to put in a high-flow muffler (either a dual-in/dual-out or two separate mufflers like I have) in the mufflers place. You can also replace the resonators with a new pair (Hushpower makes a nice stainless set for pretty cheap), or you could do a resonator delete also if desired and just run from the catalytic converters to the new muffler.
Therein lies the problem, with a 6cyl. you really can't get the deep rumble like an 8cyl. with an aftermarket exhaust. I would definitely recommend keeping the resonators or replacing them with some aftermarket ones. To get as close to rumble as possible you would probably need to use a chambered muffler like a Flowmaster or something of the sort. Those are geared more towards sound than performance and longevity. They aren't stainless steel and they can lower EGV's but I think they will produce the sound you're looking for.Innovazn wrote: what would be the smarter idea? keeping the resonators i would assume... i want my car sounding loud with a low grumble. i just absolutely LOVE rumble... but forsome reason hate the small cars with their screaming whines
I actually thought of going this route, however, given the awkward exhaust setup and the lack of space under the vehicle it really wasn't feasible. The only place to put the X-pipe would be right before the muffler, but there isn't really any space there either. The only other way to incorporate an X-pipe would be to run the exhaust lower that the current setup (making it visible from the side of the vehicle) but that isn't really a great idea since it will be more vulnerable to rocks/curbs/etc.sicwitit wrote:instead of resonators, why not use x pipes? they are lighter, and cause a similar effect? if you did 2 x pipes downstream of the cats, and pre muffler, it should make for an interesting exhaust sound.
