maxnix wrote:He might be thinking about my FGY33 for which it is true.
Because the spring seat is higher on the G50 rear, the Z32 link will work. Wes has them.
Jesda wrote:
ZOOM IN:http://www.q45.org/cpg/albums/...p.jpg
If that is so, then call Joe for the OEM replacemnt and you willl be good to go.jamesmost wrote:thank you Jesda....so the 55131m is the uca ???if so that is not my problem probably 55110p or 55120 - shot bushings causing wheel to wobble when brought up on lift...
Price disparity makes no sense. Was this IoS to whom you spoke?jamesmost wrote:ok just got under car and spoke to infiniti the part i need is 55120 (RH) & (LH) rh is $89.20 and LH is $44.50
maxnix wrote:Price disparity makes no sense. Was this IoS to whom you spoke?
I don't see the advantage of going with non-OEM part.
maxnix wrote:How about just the bushings? Seems like the metal should be good unles damaged.
Q45tech wrote:Obviously the arms must match the subrame and the rear wheelbase, even an 1/8" difference is significant if camber and toe are to be oem.
Obviously adjustable arms can be made to fit.
Interesting to study HOW oem design changes TOE during acceleration and braking vs static alignment to optimize performance during that facit of operation. HINT same general ting happens on front.................excess negative camber dilutes BRAKING ability.
Glad to hear it. I just replace my front UCA's and I wish I had known about the 300z option. Now I have an intermittent shimmy from 75+ MPH that wasn't there when I had the shot bushings and messed up rack.jamesmost wrote:confirmed done fixed. got 2 Left Hand Sides 55120+A $44 each...just like the 300z uses....Which would confirm that the 300z aftermarket arms (spl, etc) will work as well,,,,,,,,,,,,,,,,,,,,,
Solved my Mystery shimmy @ 90mphPutting it to the ground solid now...Also got rid of a weird feeling while brakeing...James
I have a set of z32 rear upper control arms I got last spring for my Q. I brought these to my mechanic, he mounted them but kept the stock upper arms because the set from spl didn't clear the shocks. I paired these with eibach springs and tokico blues.
