Chrispy300 »
https://forums.nicoclub.com/chrispy300-u87611.html
Wed Feb 03, 2010 12:41 am
Need everybody's thoughts on some issues I'm having with the Zed.
I made up the intake today, 3.5" 45deg elbow to a piece of 3.5" stainless with two ports, one for IACV and one for PCV's, also a vac nipple for the carbon canister and EGR (??). After that it goes into the AFM, then 3" down to the Apexi pod filter in the left had side SMIC position.
I'm still waiting on the last bit of silicone to rock up, so I duct taped the bit of stainless pipe to the AFM as a temporary measure.
I started it up and it idled at about 800rpm, which I thought was a bit strange. I looked at the engine for less than a minute then the engine just konked out. Started it up again and it runs real rough and stalls again. Check error codes and it has auto transmission (which I expect, haven't had a chance to put on the manual tune onto the nistune board) and knock sensor fault.
I clear the codes, it starts up ok, then within 10sec of running it throws both codes again and stalls.
Fuel pressure is good, I have a mechanical and electronic gauge both reading the same (42psi with no vac line connected), oil pressure is good and the engine sounds ok mechanically. I've got the throttle body coolant lines hooked up too. It smells like it's running rich though, wish I had the wideband hooked up...
The weird thing is a couple of weeks ago it was running fine. Took it for a drive, hot and cold idle where spot on, no complaints but did have the same error codes as above. I replaced the knock sensors before I put the engine in too. The old ones looked fine but I had new ones from a Z32 so I used those. That might be the issue... Can I just bypass them with a 550kohm resister in the mean time?
