Car won't shut off
DriftX
Car: '89 240sx
wired up my friends 240 for an sr swap, fired up first time and idled perfect, but when I turned the key off, it wouldn't turn off. Had to pull alt fuse in order to do so.
Is there any common wire that is crossed or mixed up that provides power from switch to both fuel pump and ignition?
I'm thinking ignition switch may be faulty as the car ran fine before and the wiring harness out of another car ran great before as well.
If needed I can give you a list of all wires wired up and where to.
Any insight will be appreciated and whomever finds out what's wrong with it will get a small paypal donation
-Cheers
TLP_280ZX
Car: 89 240SX
BUMP* im the friend that needs the help lol
TLP_280ZX
Car: 89 240SX
Grey Plug
Blue/Green - Blue/GreenBlack/White - Black/WhiteRed - --------- - RedGreen/Yellow - Green/YellowBlack/Red -----Black/Red + Blue/Red
Brown PlugBlack/Pink ----Black/PinkGreen/Orange - Green/OrangeBlack/yellow ---Black/YellowRed/Black ----Red/BlackBrown------Brown
Dash plugOrange - OrangeBlack --- BlackBlue/Black - Blue/BlackYellow/Red - Yellow/RedYellow/Green - Yellow/GreenBlue/Green - Blue/Green
If you see anything wrong, please let me know thank you
DriftX
Car: '89 240sx
bump
TLP_280ZX
Car: 89 240SX
bump
TLP_280ZX
Car: 89 240SX
bump
TLP_280ZX
Car: 89 240SX
bump bump bump, no one?
TLP_280ZX
Car: 89 240SX
bump
TLP_280ZX
Car: 89 240SX
well it started misfiring and narrowed it down to cylinder #4 injector was not providing fuel. pulled injector one off and car bogged, #2 off and it bogged, but when u unpluge #4 it doesnt do anything :/ but.... i still doesnt solve the problem of car not turning off with key. have to pull main power
TLP_280ZX
Car: 89 240SX
bump.
TLP_280ZX
Car: 89 240SX
well spark plug in cylinder #4 wasnt even tight. tightened it, no difference. swap coils with cylinder #1, nothing. put a noid light on injector plug, signal. but misfiring does go away when u rev past 2k rpms.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Well, since no one has answered (and I'm not a wiring person) and you're willing to pay a little bit, try contacting Wiring Specialities for advice (you know with a $30 advice fee or something). You could also try e-mailing Hijacker (SR moderator) or mrgreeneyes (his NICO screenname) I believe he is the guy the Lancaster PA members call the wiring guru. GL
Emperor_Tha
Does the car have a turbo timer? Make sure the ground is hook up properly.
TLP_280ZX
Car: 89 240SX
no turbo timer
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
try unplugging the leads to your alternator and see if your car cuts off I have seen problems with alternator wiring do this and I have also seen shorted alternators calls this problem if you cancel them out of the program and your car starts and cuts off properly your wiring problem is in the charging system start by having alternator checked and make sure you didn't reverse a wiring to the plug that go to alternator.
TLP_280ZX
Car: 89 240SX
already tried that. my friend is a nissan wiring guru and he narrowed it down to the ECU. so new ECU on the way from Japan
TLP_280ZX
Car: 89 240SX
woot woot, ECU is here, and will be in by thur, will keep u guys updated
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I don't see how the ecu can cause your car to not shut off. My understanding is the ignition switch being turned off kills all power.
TLP_280ZX
Car: 89 240SX
it may be connected to ECU somehow? replaced ignition switch and no luck. but ecu is gonna be in next thur...hopefully
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Check the ignition switch pin, take the ecu out and take the cover off and take the trace that goes to that pin and figure out if its burnt somewhere. Usually it will fry the diode that looks like a small ball with a grey stripe on it. It only is supposed to let power go one direction and when power surges through it, it allows power to travel both ways. It is repairable but you need to make sure thats the problem first.
Most commonly its caused by the Mafs wiring shorting out somewhere.
DriftX
Car: '89 240sx
Ecu is burnt. That diode is fried.. looks like a main power wire touched ground on the harness. It's being repaired and new ECU is here.
deeznutz98
Car: 90 300ZX NA
Did you ever find out why your car won't shut off? I have a Z32 that won't shut off and was thinking that maybe it could be the same problem.
PyR0NiAk
deeznutz98 wrote:Did you ever find out why your car won't shut off? I have a Z32 that won't shut off and was thinking that maybe it could be the same problem.
Try the post directly before yours.
DriftX wrote:Ecu is burnt. That diode is fried.. looks like a main power wire touched ground on the harness. It's being repaired and new ECU is here.
TLP_280ZX
Car: 89 240SX
ECU fixed it however i need a new ignitor also but at least the car will cut off now
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
OM3GA wrote:Check the ignition switch pin, take the ecu out and take the cover off and take the trace that goes to that pin and figure out if its burnt somewhere. Usually it will fry the diode that looks like a small ball with a grey stripe on it. It only is supposed to let power go one direction and when power surges through it, it allows power to travel both ways. It is repairable but you need to make sure thats the problem first.
Had this happen in my SR that I had when I was in the states, maf was improperly connected by prev O. (Read: solder & wires ended up touching ) blew the hell out of the ECU, and yup, damn thing kept running. Had to get a new MAF & ECU (it was way past gone).
TLP_280ZX
Car: 89 240SX
soo... turns on and off now but misfires. new ecu, ignitor chip, coil packs and plugs. coil harness was kinda ghetto so thats suspect, can fuel pump also cause it not to run right? its a worn SOHC fuel pump right now ha. wally 255 on the way, with coil harness, u think this should fix it?
