JBarnes »
https://forums.nicoclub.com/jbarnes-u152914.html
Sat Jan 30, 2010 9:26 am
Ok so there we were driving down the snowy road minding our own business when the engine cuts off. Limped it to advance they scan it, comes back knock sensor. Obviously I’m expecting the worse with this thing after hearing the outrageous cost in replacing it. My question is would the knock sensor cause the engine to shut off? When I try to start it after it cuts off it acts as if it’s not getting gas. So I checked the cap, when I first opened the cap it sounded as if air was rushing, not sure if it were coming in or going out. Tried to start it again and acted the same way. If I let it sit for a while I am able to start it and drive it for a mile or so. So give me your best guess…. Oh one other thing, the tires were rotated prior to this happening. Not saying that has anything to do with it but maybe there’s a line or something that could have been damaged. Thank you for any input you may be able to provide!
Modified by JBarnes at 12:31 PM 1/30/2010
