Postby
LEMHEAD16 »
https://forums.nicoclub.com/lemhead16-u7080.htmlTue Jan 26, 2010 8:05 pm
So I really want to add a consult port for data logging and such.
1990 s13's didn't have Consult to my knowledge so it looks like it going to be a fresh start for me. I'm not sure exactly where to start but here is the list of things I think I need so far.
Consult Plug and Wiring (Q45 ECU side)Ebay Consult plugconsult software on laptop
I haven't even really looked into it that far yet so any advise is appreciated.
Postby
solidglobe »
https://forums.nicoclub.com/solidglobe-u33309.htmlWed Jan 27, 2010 6:48 am
i know the s13 91 and up had consult plug. i know for sure 89 did not have consult plug.as far as 90 you should just check in the driver side fuse panel or under the dash on driver side for consult plug. if it doesnt have it you can add on you have to run wired from ecu and also power and ground wires. positive should be switched circuit.if you wire one in you will at least be able to mount/place it anywhere you want. i.e right next to ecu save on time since you will only need to make short wires and you wont have to runn it through the dash
Postby
Chrispy300 »
https://forums.nicoclub.com/chrispy300-u87611.htmlWed Jan 27, 2010 7:53 pm
If by a hundred you mean 6, then yes. Only 3 are required to make it work though. I only have 3 connected in my Z with the VH running and it works fine.
Postby
Carl H »
https://forums.nicoclub.com/carl-h-u9196.htmlTue Feb 16, 2010 1:16 pm
the SOHC s13 chassis stateside did NOT have a consult plug which his car is.email me and i can help you get it sorted, you'll need a plug from a consult car in the junkyard...easy as.
