I'm pretty sure I still have all of my wiring information and diagrams and whatnot. I'll have to go to the garage and see what box the alarm box is in and I'll post up the wiring information and colors. Also, I am assuming that the wiring data is the same for the Pathfinder and QX4.
Nissan utilizes two starter wires, a standard starter wire and a cold starter wire. You will need two relays to power those two wires (which will go into the 5901 for the starter kill). I should still have the relay diagram for that and I can post that as well. You will also need a relay to allow the unit to control the interior lighting.
Also, don't forget that you will need an immobilizer override module. The module you will need is the XK05 (
http://www.xpresskit.com/produ...d=346 ). Also let me point out that the unit will NOT come with the proper firmware to work with your vehicle unless you buy the unit from a reseller which can program it for your vehicle. You will need firmware PKN2 v.3.00 so the unit will work with your vehicle. You can also purchase the USB cable so you can hook the unit up to your computer and download the firmware form the XPRESSKIT website and then upload it to the XK05 module once you receive it. A third option is to find an authorized XPRESSKIT retailer in your area that already has the USB cable and can upload the software to the module for you.
Once I find all of my wiring information I can post up all of the information you will need to install the 5901.
Modified by Pwnin O'Brien at 11:14 AM 1/26/2010
