S13 alarm/remote start neutral safety switch
Post all your Nissan electronics, car audio and stereo questions here!
motoman399
Car: 98' wrecked (RHD coming soon) 240
ok so im putting an alarm/remote start on an s13 that has power locks. im having trouble with two things. first the lock/unlock. it appears that it takes a negative signal to both lock and unlock the doors. would i need two relays to make that happen? or is there a better way? also i cant find a good ecu pinout for a 91 ka24de anywhere. i need to know what pin the neutral safety switch is at. i dont want this car starting in gear . anyways i know you guys are very smart in this part of nico and am hoping you can help. thanks
motoman399
come on. anyone??
the converted...... Broadfield.... anyone..... please......
motoman399
ok well i did more searching. and i found this.
http://www.the12volt.com/doorlocks/page2.asp#n1
that solves the door locks. now i still need the ecu pinout with the neutral safety switch. i cant find one
oh and can a mod fix my title so its easier to search for someone else. thanks
Infinitiguy19
Not exactly your answer but this might help: http://www.the12volt.com/insta....html.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I have been traveling, so I haven't been much help on the tech front. In my Max the wire was a green with yellow stripe if I remember right. I should be able to dig through the fsm after I get home from San Fran on Monday, but I'll change the title to see if someone else knows.
motoman399
Paul Wall wrote:Not exactly your answer but this might help: http://www.the12volt.com/insta....html.
thank you. i found that one before i started the alarm and also at commando alarms also.
the converted wrote:I have been traveling, so I haven't been much help on the tech front. In my Max the wire was a green with yellow stripe if I remember right. I should be able to dig through the fsm after I get home from San Fran on Monday, but I'll change the title to see if someone else knows.
thank you. i checked the fsm today actually and it was hard to understand and follow. i think on the s14 its green/yellow also. but as far as i could tell on the fsm for a 93 its green/orange. im assuming they are the same on the 91-93/94. well thanks for chiming in and i hope to hear from you soon and have safe fun travels.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Looks like it's pin 35, 5 in from the top right wire. Just make sure you test it before you hook it up.
motoman399
thank you. i looked at the fsm and found that i thought it was pin 44 or 35. havent gotten a chance to go to my buddies and test them. ill post up a positive pin location and wire color when i find it.
Return to “Nissan Audio / Entertainment / Security”
