EnjoiNismo wrote:That bolts that you are using to bolt up the caliber is from a 300zx or a 240sx?
The 300zx bolts are too long and will go to far and hit your rotor.The 240sx bolts do not.
your problem lies with either one of these.measure the rotor.should be exactly 30mm.artman540 wrote:Sounds like you've got 30mm rotors with 26mm calipers.
Do NOT do this. People have been successfully doing the 300zx brake swap for years. If you need a washer then something is wrong. Your brakes are the most important system in your car. Fudge around only if you do not respect your life or the lives of others.WhiteZenki23 wrote:also u can use another washer to move out a bit the caliper from the rotors that s wat i did ..in between and it works perfect
Modified by WhiteZenki23 at 6:23 PM 1/5/2010
i got my rotors from ebay for a 90 z32 non turbo, it says 28mm on the rotors.so 28mm rotors on 26 mm caliper, will this work?artman540 wrote:Sounds like you've got 30mm rotors with 26mm calipers.
i used the 240sx bolts to hold the rotors in placed.it is not hiting the rotor. the rotors just seem to be stuck after i bolted teh caliper on..EnjoiNismo wrote:That bolts that you are using to bolt up the caliber is from a 300zx or a 240sx?
will a 28mm bolt fit into a 26mm sized hole. No. You can't out something that has bigger diamiter into a smaller diamiter hole.fresno240sx wrote:i got my rotors from ebay for a 90 z32 non turbo, it says 28mm on the rotors.so 28mm rotors on 26 mm caliper, will this work?
i keep seeing this lately. where is this 28mm size coming from? no z32 ever came with 28mm brakes. it's either 26mm or 30mm.fresno240sx wrote:it says 28mm on the rotors.
As far as I know, Nissan doesn't use 28mm rotors.numbnuts240 wrote:i keep seeing this lately. where is this 28mm size coming from? no z32 ever came with 28mm brakes. it's either 26mm or 30mm.
Beautifully Coated z32 Caliperman i wish i had powder coated mine.94_240sx wrote:
