2002 Infiniti QX4 Stalls in gear when cold
swhitey02356
Car: 2002 Infiniti QX4
I've replaced the solenoids, fuel pump filters etc. Any ideas or thoughts as to why the car stalls upon startup?
fixer
Car: 08 Sentra
CK FOR START SIGNAL FUSE IN FUSE BOX. IF IT HAS ONE
Q451990
Welcome to NICO!
Does the idle increase when you turn the a/c compressor on after the car is warmed up? Is the idle higher while the car is warming up? If not, you may have a bad AAC valve or fast idle cam problem.
Heath
silkysmoothyjud
Car: 1994 Q45
could be fuel pressure related or maf as well, or a monkey with a hand grenade under the hood about to pull the pin
