nifares240 wrote:I noticed in your pic, the tensiod rods are not even flush to your front brace. I have the spl ones, and they fit flush on my stock brace. tensiod rods have the tedency to twist when braking and hitting bumps. you might be getting side to side play.
Not really sure what your talking about. I took that pic when I was finishing up installing that brace, so the bolts aren't all the way in. I just posted it so people would get an idea of what I was talking about...and people are more likely to click on your thread if there's a picture
gumby74 wrote:I have run the Tein (my personal favorite) and currently an older model of the Kazama rods that I lucked out on. Thick steel rod, very stout. No clunking caused by either set. I may however suggest you check your balljoints, and control arm bushings.
Looks like the higher quality rods don't have any issues (go figure ) My ball joints and LCA bushings are new.
94_240sx wrote:Simple. They went bad. Housing that holds the bearing got stretched due to weight shifting or bearings are damaged somehow, so there's play inside. Replace them with better ones. You shouldn't get any clunking noise or movement and that's the whole point of having pillow ball joint tension rods. I have Kazama ones and they are good.
That's what I had figured but i wasn't sure since nobody had posted anything about it. Just wanted to verify. Looks like this gives me an excuse to get some SPL
On another thought, has anyone just replaced the pillow ball joints in their tension rods? (whatever brand)
