Freyspath »
https://forums.nicoclub.com/freyspath-u146169.html
Tue Dec 15, 2009 2:26 pm
Hey guys, I decided to make another thread on this topic because the other one started to die out, because links werent working anymore... This thread is all about the gauge clusters, nothing else...
So ever since I got my 2003 LE I love it, but I dont like the white face gauges, it looks "old" so I wanted the fresh look they put on the 2004 LE Platinum Editions. The difference is the 04 LE one uses incandescent bulbs, while 2000-2003, and 2004 SE's use small little bulbs that dont produce much light at night.
Here is the break down:
2000-2003 LE, and 2004 SE gauge cluster:2004 LE gauge cluster:
So my goal was to switch out my white faced one with the 2004 one. I found an ebay seller who dismantled nissans and got him to send me an 04 LE one for like $140..
Then I used the DIY on the forum to remove mine and simply plug in the new one... so I thought..The removal of the 03 one was very easy, but here is where I ran into problems:
First let me show you how they look (front and back). The one on the top is the new 04 one, and as you can see it has all these bulbs for every little notification, unlike ours.
The first thing I noticed was that the cord that hangs out of both of them, which is for the 4wd screen was different.. The 04 one had 6 cords, while the 03 one only had 4! One was grounded, which left me a red wire which was "extra". Secondly, the harness is different!
So since it wouldn't plug in I decided to just put the old 03 one in place of the 04 one.
I took the red wire and but it with the pink one, in hopes that it was just an illumination wire that would just be on 24/7.. ... That didn't work when I plugged it in the first time around into the car, so I decided to remove it from the pink, and wrap it.. That didn't work either!
When I plugged it into the car, both times (once with the red wire attached to the pink, and the other time with it just unplugged) I had troubles with the cluster. Here are the problems: The problems: - The illumination wasn't working, so it was dark as hell, and even with the lights on, it wouldn't light up. - VDC OFF and Tire Pressure Low lights were illuminated.. I dont have on my pathy VDC or TPMS. - The 4wd screen wouldn't show what I was in.. 2WD, AUTO, 4WD Hi, 4WD Low, none of them light up! - The panel that showed what gear I was in (PRND21) didn't work. Only OD OFF would light up - Lastly, I went from 82,410 miles down to 79,864! ..So I had to put the old one in until I figure out what the heck is up with this thing! As I was cleaning up I noticed all the ground came from one spot.. This little slit on the front left of the cluster, and maybe I need to run a GND wire to it?? ..So if someone has a wiring diagram and can see the differences to these guys, that would be greatly appreciated, cuz im stuck... In the mean time im going to play around with it a bit, but I wont get far until the new years cuz we have family coming over and my folks said no car work while there here
