Oh DAM!sean@z1 wrote:OR get the whole thing including the lock which is diffrent and a new set of keys for 388 +40 dollars for shipping.
http://www.z1motorsports.com/2...=3475
nope, that wont do it. you will never be able to get the us trim to fit perfectly. you can easily make it work by gently hammering the trim where the curve of the taillights is, but it will still be inset. even with some sort of spacer wont work because by the time the top is flush the bottom is hanging out. the jdm trim has a crease half way up so that its flush every wherechaosli wrote:all you need is some spacer and or screw driver
