Need Help removing Pulley on RB25...
johnny butt
Car: 1993 240sx Convertible
Hey guys, I am currently in the proccess of doing all of this:
zer...wpics
Really nice and straight forward guide, only problem is me and 4 other mechanics are having issues removing the pulley seen here:
(taken from the guide:)
Any tips or suggestions? I can't change out my stuff until it's off.
d356bud
Car: 1990 240sx w/ RB25DET
remove the starter and prevent the flywheel from spinning by using a screw driver or crowbar. There are two bolt hole on pully use a steering wheel puller and two long bolts I forget the size there small and have a fine thread.
eh?
I use a large gear puller very carefully.
crazyandevil05
Car: 1995 240sx SE, RB25
Instead of removing the starter, all i did was put it in 5th gear, e-brake and wheel chocked to keep the engine from turning. has worked great every time i've taken mine off (about 5x now)
Bluefire
3 jaw gear puller.. pulley is out in less than a minute
s14_sport
Bluefire wrote:3 jaw gear puller.. pulley is out in less than a minute
+1
just did this tonight...works like a charm
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Throw it in 5th gear and use a 3 arm puller.
