Squeeling
NicUzumaki
Car: 240sx-dohc swap
82dodge Rampage[RIP]
So its a 90 240 sx nissan with the s13 engine,and it Squeels at start, or when slowing
i'm thinking timing belt, but was curious if there was something else that common failed.
thanks again
lumski240
Car: 89 DOHC 240sx Hatch
bump
Klits562
Car: white s13 coupe
when you say the s13 engine do you mean the ka24 or the sr20the ka doesnt run off a timing belt and but the sr20 does.This is most likely belt screech so which ever engine you have just check the tension on all the belts make sure they arent to tight or loose.You should only be able to move the belt abpout 1/4 an inch.
chalmer240sx
Car: 1990 nissan 240sx
yea check your beltsdeffinty check the cerpatine belt!!!!!!
s13tomf31691
check your water pump..if its squirting water then it might be that
tyrodtom
Car: 90 240SX
It's one of your fan or alternator belts too loose.Timing belts can't squeal more than a fraction of a second, and once only. They have cogs, if it shears off the cogs, it slips, the engine jumps time and quits running.If you have a KA24e, or KA24de, you have a timing chain not a belt.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
ka's and sr's have timing chains and thay dont squeal. rb's have a belt and if it squeals your hosed. chances are its your alt or p/s belt.
wrightme43
Car: 1991 240SX SE, 5sp, Super Black
also always check all the pulleys and componets when you change a belt. Sometimes the bearings are failing and that will cause a belt to squeal as well.
NicUzumaki
thanks for all the help,i'm working on not being a noob.all the work i've done has been bondo and sanding
Billiam151
I would say that it is your power steering belt. when it squeels try turning the steering wheel? if there is some resistance then its the power steering belt. Mine is currently doing it and noticed at start up I tried to turn the wheel a little and it had some resistance. Just my two cents.
