05 max rotors stuck
redboy
Car: 2005 max se
any tool out there that will get these off would rather not use the bfh trick?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Once you have taken out the brake caliper and torque member, normally, you can wiggle out the rotor. However, some rotors could be stuck due to rust. In that case, you may need a hammer/mallet to remove it. You can use the hammer in conjunction with WD-40/PB Blaster (do not spray on the rotor contact surface). Hammer only on the hub-side as much as possible as the rotor could be damaged.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Some aftermarket rotors have a bolt hole that allows you to screw a matching threaded bolt into the rotor face to pry against the hub and break it loose. I don't think the original factory rotors have that feature, though...I don't recall for sure.
