no problem man glad it all worked outdvorkink wrote:Spent 5 hours today taking out both headlight assemblies.
I purchased an OEM ballast from another nicoclub member (thanks Mike). The plastic piece which connects directly to the bulb was slightly damaged during shipping. I glued the connector together again and secured it in place with some electrical tape. I then removed the old ballast (not easy as the connector is a tight fit through the headlight assembly and it took 20 + minutes to force through). Then I took the new connector and guided it through the assembly. I then connected it all back together including connecting it to the car power source and flipped the switch = nothing. The light didn't come on.
I then removed the driver side assembly and connected it to the passenger side. It lit up perfectly. That eliminated the fuses and the wires to the headlight assembly as the issue. I then got a voltage tester and checked the wire that connected to the ballast on the passenger headlight assembly when connected to the car. It tested fine. Power was getting to the ballast. I was stumped since the ballast had been tested before it was shipped to me.
I then decided to try one more thing before giving up and either heading to an auto electric shop or the dealer. I took the undamaged connector off of my old ballast, removed the glued and taped together connector from the new ballast and put it all back together for one last try.
It worked. What a pain in the butt. If the connector hadn't been damaged in shipping my day would have gone a whole lot smoother.
Thanks for all of the help.
Do it yourself and read your trunk!MichelG wrote:I am having the same issue. Discovered front right low beam is out. High beam still works. Nissan dealer says it is an electrical ballast issue which will cost about $2600 to fix!!! That sounds insane. I'm calling around to other dealers/independent shops to figure this out. Any final thoughts?
