95 S14... CKP & EGR issues...
S14_T3RR0R
Car: 1995 Nissan 240sx
Ok my 240 is throwing 2 codes: P0335B-ckp a a circuit malfunction P0400-EGRnow I got the replacement CKP which i understand is located on top of the bell housing. i havent gotten around to taking care of it. my question is this: Are these common problems that occur together? and is the egr something that can be fixed with a thorough cleaning? I read it can be fixed that way. sometimes.(Im not saying 100%)
S14_T3RR0R
Wow... a lot of help... A plethora in fact.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
The crankshaft position sensor code does not have anything to do with the egr code.The egr problem could be a number of things(valve, temperature sensor,vacuum hoses etc).You might try cleaning the egr valve,its easy enough to do.I would replace the crankshaft sensor for sure!Good luck.
S14_T3RR0R
For sure good looking out.
sx moneypit
1986 Toyota MR2
No problem brother!
